Sony HVR-A1E HDV Digital Camcorder Logo
Anonymous Posted on Nov 22, 2017
I have 2x sony hvr-a1e hdv digital cameras. a couple of years ago they were used in sri-lanka and india. when i left sri lanka 35c on landing at heathrow temp -3c since then there has been problem on both cameras with both cameras not working because of warning relating to condensation problems, and help would be appreciated.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jun 24, 2006
SOURCE: Camcorder shows condensation problem most of the time
Its a possibility that the sensor could be bad but I'll bet that its a small surface mounted capacitor thats bad. These are common for the caps to go bad, and when they do start to leak, the camcorder should be taken into the shop asap, AS THE LONGER YOU WAIT THE MORE DAMAGE the Capacitors will cause, as they eat up the tiny traces on the board and then the board has to be replaced. Good Luck
Broadcast Innovations
  • 72 Answers
  • Posted on Jul 06, 2009
SOURCE: Sony HVR-A1P condensation warning
dnt do it bcos u will nt be able to reach the dew sensor as ur nt a proffesional so,
just keep the camcorderi9n stand by mode and keep it in front of ac or so..
Anonymous
  • Posted on Jul 13, 2009
SOURCE: HVR-Z1E Capture problem
Hi George, Sounds like you and I are of the same level with this Cam and editing , would love to compare notes with you if you would care to drop me a line [email protected]
Pat
Anonymous
  • 10594 Answers
  • Posted on Aug 31, 2010
SOURCE: Hi, I need a replacement Firewire port for my
Can you tell me what board is written on it, like its JK board or JS board etc.
I have service manual of this camcorder and will provide you part number info, just let me know board name/ number.
Thanks.
Anonymous
  • Posted on Sep 19, 2010
SOURCE: Sony camcorder HDV 1080i model HVR A1U won't eject
Sony A1U stopped functioning. Neither AC power or battery yields anything. Reset button yields brief flash only. Tape stuck in machine. Help?
The menu icon wont function
This video goes over the problem you are having.
Zoom
hi,
yes it has, go in camera settings
but if advise you, better not to use it because too much pixelizing with deep zooms (that's why it is desactivated from the beginig)
1helpful
Cannot shut the cassette chamber of my HVR A1E Camera. Shows C32:11. Have already tried a lot of internet tipps, but without success. What ca I do
Dear
need not try any tips, as its the problem of mechanical deck, which is giving this problem it needs to get replaced, as the cable on the back of hvr-a1, mecha deck gets broken....
due tow hich the error starts coming...
get that replaced
1helpful
My Sony camcorder often stops and a writing appears: "Use the infolithium battery pack" It happens either when I am recording or I am watching the tape and can happen any time, after five minutes, ten...
It sounds like you are using an aftermarket (non-sony) battery pack. The camcorder you are using probably requires the Genuine Sony 'Infolithium' Battery pack (usually in the box of the camera). If you are getting this message with the proper battery installed, i would contact SONY
1helpful
Do you get HD quality by outputing to TV using
no ,but you will have a dvd quality picture. HD means
the picture size format usely 16:9, HDMI its a Hd
multimedia interface its HD quality to...
hope that help you..
1helpful
2answers
Large viewfinder only works when reversed &
dear ... there is an option in the menu .....
of hvr A1 TO KEEP THE VIEW finder.... ON..
write nw
ur camcorder is in auto mode ,wht happen in auto mode is ,view finder gets ON only when u turn the LCD pannel ...
so need nt worry change ur MENU option OF view finder from AUTO to ON,......
How can I avoid camera moisture condensation on my Sony a1e camera, it keeps saying turn off for one hour or eject tape and is doing this constantly.
Camera gives Moisture error sign if it really have moisture condensation inside or its moisture sensor itself got defective.
if moisture is inside, blow hot air in camera mechanism for 5-6 minutes by hair dryer (not so closed with mechanism) and check / test.
If problem still exist it means moisture sensor is defective and i know its Sony high-end model camera and know how to fix it yet I would recommend to take camera to Sony Service center for proper repair.
We have a sony HVR-A1E Camera, are using the AV connecting cable and unable to get it to connect to our tv play back footage. Can you help?
Just a thought but have you got the right format selected?
Try this;
Press 'P-menu' on screen, then select 'VCR HD/DV'.
Make sure that you then select either DV or HDV depending on which format you filmed in. The 'auto' function doesn't always select the right one!
Oct 27, 2008 • Cameras
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
