It's not cold outside, It's hot. So I dont think it sould be running all the time like this.
SOURCE: hello! the pump on our qca majestic hot tub
If you live in cold weather and are not using it much lower your thermostat. If the freeze control kicks on (at about 38-40degrees) it will constantly try to heat the spa to where you have the heat set when the air temp is low. Hope this helps.
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Hello burnelltolbe - If your refrigerator is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the sealed system that only a professional can help with. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evaporator fan, coil or coolant lines. I suggest cleaning the unit out including the coils you can reach, and make sure no food items are blocking any vents in the unit. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If any suggestion proves to be ineffective contact a professional to move forward accurately.
