I have accidentally deleted all the files from my USB memory flash. Is there a software which could aid in returning these lost files back to my USB?
Asoftech data recovery program can recover data from formatted, lost or damaged hard drive or partition, Ghost hard drive .
# Recover lost, formatted or deleted ( word ,excel ,ppt, office document, video zip, photo files etc ) from hard drive, Support USB recovery and other disk recovery .
http://www.asoftech.com/adr/
As it was a SanDisk flash drive, why not use the software they have to resolve such a situation?
Try SanDisk RescuePRO, and have it scan the drive to see if the deleted files are recoverable. https://www.lc-tech.com/pc/sandisk-rescuepro-and-rescuepro-deluxe/
As long as there was no issue with the drive, it should be safe to re-save them back to the drive.
But, to be sure, it would be a good idea to save those files in more than one place. Like maybe an extra flash drive, or to "the cloud". always have more than one backup.
Hey, I know there is handy USB flash drive data recovery software that can deeply scan your drive and rescue your wanted drive files back as many as possible:
http://www.ucfix.com/data-recovery/data-recovery-after-format-external-usb-disk.html
Simply download this software and choose a fixable data recovery mode from four to scan your drive. And then, preview all scanned drive stuffs to restore all your needed ones back with success.
In case of similar data loss troubles, never forget to prepare data backups again.
Don't worry! Without new stuffs written on this USB flash memory since the deletion, you can easily take them all back with USB flash drive data recovery software to get all your deleted files back within several simple clicks.
With a right data recovery tool, you often can deeply scan this flash drive and find your preferred drive files back as many as possible.
Note: In the future, in case of similar data loss problems, prepare drive data backups well all the time.
Hi, there!
This USB
drive data recovery freeware would be what you are looking for:
http://www.freeware-fix.blogspot.com/2013/03/usb-drive-data-recovery.html
This freeware really helped a lot as my
hard drive was mistakenly formatted by my bother and all the inner saved files
were gone. But, with the help of this freeware, I had eventually restored all
my wanted files back.
So, if you are interested, you could
directly download it here:
http://freeware-fix.blogspot.com/2013/04/usb-drive-recovery.html
Remember to back up everything important at
least on two drives.
Hello, No need to be worried anymore since it is quite
easy to recover lost files from flash
drive by using lost file recovery software. Even I had encountered this
kind of issue where in some of my important files from USB flash drives were
lost due to accidental formatting. Then one of my friend suggested me to this
tool which really recovered all of my lost files. You can try the software by
downloading it online or by clicking here. All the best John Stephen
USB flash drive is widely used for its excellent quality which gives customers all the power and performance you need to transfer, store and share pictures, tunes and data perfectly. And once you accidently deleted data from USB drive, you must be very worry, especially when you deleted or formatted important data. How torecover data from USBthen? It is actually very easy.http://www.card-data-recovery.com/usb-data-recovery.htm Only 3 steps: Step I. Download and Install the Program The program takes very little space, thus the downloading process is very quick. Step II. Choose Device and File Types to Be Recovered Specify the device signifying your card in the interface of the software. And then you could choose file types on the right of the interface. StepIII. Preview and Recover Files
Just visit the link given below
http://www.wondershare.com/disk-utility/pen-drive-data-recovery.html
usb drives dont have manuals the computer automatically detect the drive.
in saving files it is the same when you save in a floppy or other drives.
SOURCE: The USB connector broke!
I did the same to the cruzer as tedthehobit, and here's how I fixed it.
1) Split open enclosure with screwdriver alone edge. The small key-ring will come off when enclosure is separated. (Safety glasses, please). Circuit board is attached to plastic base--the piece for sliding the connector.
2) To see amount of damage and trace connection, remove the plastic as follows. Two notches are on each size at socket end. The other end has plastic bar across on-top. Use needle-nose piler to chew away top of notches, slowly and carefully to avoid stressing board and damaging surface. This makes it easier to move the notches to the side to lift the board up and out.
3) Look at pads where socket was attached. Fairly clean break, surrounding circuit trace and pads are intact. So, it is worth to continue.
4) The socket connection side has no large pads to solder wiring. The D+ and D- traces were lifted off slightly, but too thin to attach wire. Look at the other side.
5) Use flashlight as backlight, and follow traces from connector pads to ends of closest chips where it is big enough for soldering. [I have jpg of connection points--where to post it?]
6) Use wire-warp (hair-thin and pre-stripped) wire and small-tipped solder iron and work under bright light. Tin wire with traces of solder and remove excesses solder from iron tip. Connect wire to chip, melting and using the solder already there.
7) Solder other ends of wire to the correct tabs of the usb socket.
8) Plug usb socket into a socket extender to plug into PC. Extender is optional, but it will help to deteach from PC later.
9) Did not work the first time because 5V-line solder at circuit was not good (eventually came off). Re-solder. Plug back into PC, and cruze lit up and PC can access the file.
