Sony KDL52W4100 Logo
Anonymous Posted on Jun 11, 2012
Sony kdl-52w4100 T-con board problems
Since few days by switching on the TV I have some shadows (double text) on the screen. After one or 2 minutes it disappear and the picture is perfect again. It seems that the T-con board could be the source of the problem. My question are : 1) where is the T-con board located ? 2) do I need special instructions or tools to open the back cover ? Thanks MK
  • 1 more comment
  • Anonymous Jun 11, 2012
    Hi Gopakumar,
    How I find the T-con board it is so much stuff in the blog?
  • Anonymous Jun 12, 2012
    Hi Gopakumar,
    I did read your blog regarding the T-con board in general.
    It confirm that I'm looking in the right direction.
    It my be the contacts on the flat cable ribbon connectors.
    However You mentioned that you have the service manual in PDF format available.I would very appreciate if you could email it to me : [email protected].
    Thanks
    MK
    I would very appreciate if you could email it to me available.
    Thanks Gopakumar.
    Keep you posted.
    MK
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jun 11, 2012
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15002690
Points
237762
To explain all about your problem post sill take so much time to type in all. More over, I cant insert any PDF files by this window, to show you the position of T'Con board inside your TV. Just visit this site. It is my blog. Purely meant to help to repair electronic equipments. electrohelp online.blogspot is the site address. Visit it. Google for it. To know you more, I've the service manual to your set in PDF format. Just visit this site first. You can get more details by it; about waht a T'Con board. what tools do you want to replace it. How can it be replaced and so on.
If that site do not help you, contact me. OK?
  • The Knight
    The Knight Jun 12, 2012
    I've send the service manual to your TV, a few while ago.
5 Related Answers
Anonymous
  • 34 Answers
  • Posted on Apr 29, 2009
SOURCE: tv powers off after 15-20min
chk fans 4 dust & clean if no help replace the largest visable fan approx 6"
Anonymous
  • 668 Answers
  • Posted on Oct 21, 2009
SOURCE: I have a Sony KDL 46XBR4 LCD TV. Perfect sound but
You probably have a bad LCD Panel. It is a common failure. If the unit is out of warranty, call Sony at 1800-222-SONY and see if they could help with the cost of repair. They would require a Service facility to evaluate it to be sure it is the Panel.
Hope this helps,
Skyassoc
Anonymous
  • Posted on Oct 23, 2009
SOURCE: Sony XBR4 - 46 inch Double Imaging and 1/2 screen dark
Sorry not a solution...We also have exact same problem (TV about 1.5 years old) - out of warranty - all Sony told me to try was to un-plug TV for 2 minutes - useless. I am trying to decide if I should bring to service store to try to fix. I hate to spend a couple of hundred dollars to find out it costs $2000 - less then a new one. Anyone have any suggestions?
Anonymous
  • 1779 Answers
  • Posted on Nov 19, 2010
SOURCE: WHERE CAN I BUY A SONY T-CON BOARD PART NUMBER
The part # you gave is the Control Board which sells for $668.79. The T-Con board your looking for is part of the LCD Display Panel and is not sold separately. I suggest you start by cleaning the ribbon cables from the control board to the t-con board. If that doesn't help then you had better take it in to a service center to verify which part is bad because there are no refunds, only replacement after you buy a board.
Anonymous
  • 4 Answers
  • Posted on Mar 29, 2011
SOURCE: sony kdl-52w4100, no picture 14
I had same problem with my TV and This Guy Duke he fix me up for cheaper price, Call him 416 261 6595 or check his website Dukeelectronic.com
2answers
Sony KDL-43W800C 3D LED TV colored vertical lines on the screen.
dear there is a problem in T Con board so please replace the T Con board after fixing it set will become ok
thanks
m Nasir
My sony bravo 52 inch model # KDL52W5100. HAS A DARK SHADOW IN MIDDLE AND BLURRY RIGHT SIDE. BUT THEN IT FIXES ITSELF AND 2 TO 3 DAYS DOES IT AGAIN
The part failing is called T con board , http://www.tvpartsinstock.com/sony-kdl-52vl150-kdl-52w5100-kdl-52w5150-t-con-board-lj94-02676j-15589084
, if your handy you can swap it out yourself . or pay a shop more then the TV is probably worth ( not recommended )
cost 65.00-70.00 they are a lot of screws and shielding to remove to get to the main PC board . Hope that helped a little
3helpful
2answers
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
1helpful
3answers
Sony Bravia Kdl-52VL150 has vertical lines on screen. Is this fixable and how.
usually that symptoms cause of faulty t-con board..
but before you do that kindly play dvd on your tv and look at the picture if still persisted just change the t-con board to works fine again
2answers
I have a Sony KDL - 52W4100...the picture has been awesome for two years but recently i am now getting a steady stream of horizontal lines and at top screen red and green boxes and sometimes bleeding of...
meder tv service......this can sometimes be due to t-controller board failingnot sending proper data to panel.....can order on shopjimmy.com or partstore.com....happy repairs....
I have a Sony KDL 52w4100 LCD tv. When I turn the TV on, all i get is a blank screen, and no sound.
Tad G chances are you installed the wrong Tconn as that model used two T con boards both look identical but they are not interchangeable the two types were part numbers 185724011 and 185713211 I can assist with determining which version you have
4helpful
I have a 52 sony lcd model kdl-52w4100 when turn on double image after a while it goes away i was told it needs a panel what do u think
No,the tv LCD screen panel it is good,if it fixed itself after awhile.The board that call the T-CON board it is dying and dead soon that the problems.This T-CON board sit in the middle of the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbih T-CON board for the replacement.
3helpful
2answers
WHERE CAN I BUY A SONY T-CON BOARD PART NUMBER SONY 1-857-132-11 ? IT IS FOR A KDL-52W4100. 2" Vertical stripe problem all the way across the screen. fades in and out. If iI try resoldering the...
4helpful
My 52ince LCD Sony Bravia TV is started showing 2 vertical lines on each side, but they go away 20 minutes after starting TV. What is wrong?
The tv board call the T-CON decoders board have problems,that why colors vertical lines are showing up in the tv LCD screen panel.The T-CON decoders board,this board sit wright at middle bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
2answers
Good day, I am all of the sudden getting double vision and a white line across the screen, it eventually goes away, not sure if it may be my directtv reciver?
This is a common problem for Sony BRAVIA KDL-52W4100. You can reconnect the LVDS cable to the Main board, the location # is CN4701.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
