SOURCE: my phone cannot read my memory card
same happen to my nokia 6680 it was workinf fyn but then when i put it in theres nutin on it
SOURCE: memory full
Happened to my n73 twice. Format the phone to get rid of junk piled inside the phone memory.
To format:
Your
phone will gain 44mb back and go back to normal. Phone will respond a
lot faster too, as if it were new. Viruses would be deleted as well as
other junk stuffed inside.
Important reminder:
If you
have anything stored on the phone memory that you woudn't want to
delete, such as pictures, videos, or whatever, back it up to your
memory card or computer. The format process deletes all stored memory
on the phone, but not the memory card.
SOURCE: LG shine CU720 moving pictures rto memory card.
The LG Shine allows you to do a multiple picture DELETE - but not a multiple pic transfer to memory card, at least that I've found. You have to transfer your pics one at a time from phone memory to the SD card as follows:
Select Menu --> 8 My Stuff --> 4 Pictures
Highlight the pic you want to transfer using the center toggle button,
then select Options --> 5 Move (or 4 Copy) --> 2 Memory Card --> Paste
Once your pics are on the memory card then put the phone into USB mode by selecting
Menu --> 9 Settings --> 7 Connection --> 2 USB Connection Mode --> 2 Mass Storage
Then attach a suitable USB cable to the phone at the charging jack and open Explorer (Windows) or Finder(Mac) and navigate to the phone. Your pictures will appear and you can copy them to your computer as needed.
NOTE: be sure to return the phone from Mass Storage mode to Data Service or your phone will not work.
Also - set your phone to highest resolution for best quality pics.
Menu --> 8 My Stuff --> 7 Camera and Recordings --> 1 Take Photo --> Options --> 4 Resolution --> 1 1600x1200
SOURCE: memory card lg kc550
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
