Every time I cook on my new white glass cook top- I have to scrub it afterwards using the special stuff they gave me with the scrub pad- what a pain- are my pots and pans not condusive to a glass cook top? should I be using a certain type of pots and pans? Even if i just do something easy like boil water I take the pot away and it's all burnt lookin' on the cooktop
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
SOURCE: Jennair cook top
Replacing this top is not too difficult. It is secured by four screws on each side. You might have to remove some of the flanging in the back to pull it off. Make sure to unplug the the unit. I would think that the top might be pricy, but if you take your time replacing it should be no problem.
SOURCE: numbers washing off cook top
Try taking the knobs off make sure there is no greese on them put them on news paper and lightly spray with a clear laquer,let dry and give them a second coat.
Hope this helped.Let me know by rating me
For more help go to live chat.
len west
SOURCE: burnt sugar caramelized on a Jenn-Aire glass cook top
We Use Debruce Polish on all our cooktops. Debruce also works on
stainless steel and polished granite, marble, porcelain, formica and
glass. DeBruce is non-toxic odor-less and eco-friendly. You can get
DeBruce on line at debrucepolish.com.
This stuuf really works
Me too. It is the WORST investment ever. I would not advise anyone buying a white cooktop. One tip is that baking soda works to clean and is cheap. I put a little water on stains then sprinkle BS, wait a while and then scrub. I do still have shadow areas that have never come clean. It's the pits. had it one year.
