I repalced the toner cartirdge with a new one and the machine will not reset, it keeps giving me the same request for a new cartridge.
Just take the whole assembly out of the printer, disassemble the toner and drum, assemble it and put it back in to the printer until you hear a stable CLICK. After that try it again, it should work. It's just a software bug. Affordable Brother TN350 Toner Cartridge
I Suggest You To Watch just replaced the toner cartridge and the LCD continues to Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
SOURCE: I have a MFC-8660DN that is not even three years
When you replaced the drum did you reset the counter as per the instruction sheet with the new one? I think from memory you hold the OPTION button with the door open. This gives the option of resetting the count in the display.
Good luck these are usually very reliable.
Al
SOURCE: Printer says recplace toner after I have reset a tone cartridge
I have two suggestions for you.
You might also want to review the instructional video by clicking on the link below:
http://cgi.ebay.co.uk/HP-LaserJet-P4015-P4015n-dn-Toner-Reset-Chip-CC364X-64X-/310239780829
Hope this helps. Please keep us updated and remember to rate this answer.
I don't want JUNK advertising which the answer was.
