Life Fitness 95Li Summit Trainer Build Up Your Legs and Butt Muscles Logo
Joseph Ferreira Posted on Jun 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Squeaking peddles Right pedal squeaks
ernesto cuadra
Level 3:
Top Expert:
  • Life Fitness Master 12,223 Answers
  • Posted on Jun 11, 2012
ernesto cuadra
Life Fitness Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076222
Points
34431
1) Lube inmediately, and tight the bolts+nuts, and replace any parts worn.
2) Follow the instruction manual according the schedule maintenance
God bless you
  • Anonymous Nov 27, 2012
    hi i just wanted to ask where to lube , at the metal that the pedal moves or just the roller ?
2answers
How do I stop the squeaking noise when pedaling the bike or using the elliptical option? I've tried lubrication. Only getting worse.
Have you lubricated all moving parts. Wheel bearings Chain and sprockets? Are there fenders if so are they a little loose?. Anything that is loose will vibrate and make a noise. Even dry pedals will make a noise. Crank also.Just a thought.
Break pedal squeaking
is the squeak inside the car? if so, then yes it's probably the pedal or linkage. If it's outside the car, then either the brakes were done poorly or the pads are defective. Assuming you had the front and rear brakes done. Could be the other brakes if only 1 axle was serviced.
1helpful
3answers
Left side its sqeak when i peddle
My Precor EFX 546 elliptical trainer began squeaking when my weight was on the pedals. I thoroughly cleaned the track and wheels with Windex and then used my finger to apply a thin coat of teflon based lubricant (Tri-Flow brand) to the outer surface of the wheels. After 2 applications of lubricant, the squeaking has been eliminated completely. Hope this helps!
1helpful
2answers
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
1helpful
Scraping/Squeaking noise on recumbent stationary bicycle
There are most likely some sort of bearings inside the wheel hub that are causing this.
Jan 13, 2010 • Cycling
2answers
84 Eldorado squeaks when driving and stops when i press thebrakes
shot in the dark but you may want to check your shocks
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
