I have a corded phone that also has a cordless base and phone as part of the phone package. The corded phone and answering machine work great. The cordless phone says "cannot connect". The cordless base has power and it indicates that the phone is charging. All of the features on the cordless phone work, with the exception of trying to make a phone call. The phone is less than 6 months old. Could the battery be bad? I have tried moving the cordless phone into the same room as the corded phone and I experience the same problem. Thanks for the help.
Cordless phone will not come out of the "OUT OF RANGE" mode
although it it sitting in the base
I have the very same problem and it was after storing numbers into the directory, although that may not have anything to do with it.
You may need to reset the Telephone Answering System. Complete the following steps to reset the Telephone Answering System:
Step 1: Disconnect the power to the telephone base.
Step 2: Wait a few minutes and then reconnect the power to the telephone base and charger.
Step 3: Set the day and time.
E5908 Handset says "Cant connect" I tried resetting the base, resetting the cordless (disconnect the battery), putting in the base, everything... I have had this problem for over a year.
I have two identical phones, and still use the base of the one that the headset wont connect, the other one still works fine. But one of the handsets wont connect.
I see you can buy a replacement handset... but then, how can you program it to your base... since I have two, and I can't connect the handset that is working to the other phone... is there a way to program it????
Cordless phone, doesnt seem to be charging. Phone has switched off and i cant switch it on again
Phone Model 26943GE1-A
