Electric Kid Trax C6 Corvette  Ride On Logo
nick wisor Posted on Jun 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pink corvette 12 volt will not make sounds or move battery and fuse is good
Adam Fjeld
Level 3:
Genius:
  • Electric Master 1,508 Answers
  • Posted on Jun 12, 2012
Adam Fjeld
Electric Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542705
Points
1761
Have you tested the battery and the charger with a multimeter to make sure that they are showing at least 12 volts
How do i check if my 1989 corvette a/c heater blower is getting current
Find the power wire, on your model it should be pink for faded red color, possibly purple. This is the +12 volt wire that should have power with key on and blower switch on high. THere should be voltage between this wire and ground, if not check the relay or resister, problem may be blower switch.
Kid Trax KT1021 Corvette does not start or even make a noise but meter shows battery & charger are both good and that the board is getting juice. We have followed every wire multiple times, looked at...
Safety 1st, KidTrax Battery-Powered Ride-On Vehicles Recalled Dorel is recalling about 141,000 Safety 1st and Kid Trax battery-powered ride-on toy vehicles. An electronic malfunction can occur in the circuit board and/or battery connector, resulting in smoking and melting of components.
This poses a vehicle fire hazard and a burn hazard to consumers if components are touched while malfunctioning.
The firm has received 49 reports of overheating or melting components on the ride-on vehicles. No injuries have been reported.
The recalled battery-powered ride-on vehicles include the Pink Corvette, Torch Red Corvette, Yellow Race Car Corvette, Red Electroplate Corvette, Fire Engine, and Batmobile with the model numbers listed in the chart below. They were sold under the brands Safety 1st and Kid Trax by Safety 1st.
The ride-on vehicles were manufactured between January 2004 and August 2005. The manufacture date is located on the underside of the unit and is molded into the plastic body as shown. The circle on left displays the month of manufacture, the circle on the right displays the year of manufacture. The model numbers are located on the underside of the vehicles near the date code.
Ride-On Vehicle Name Model Safety 1st Pink Corvette 50503/50503A Safety 1st Torch Red Corvette 50504/50504A Safety 1st Yellow Race Car Corvette 50505/50505A Safety 1st Red Electroplate Corvette 50521/50521A Kid Trax Fire Engine 50506/50506A Safety 1st Batmobile 50527
The units were sold at major toy stores and mass merchandise outlets nationwide under the brands Safety 1st and Kid Trax by Safety 1st from January 2004 through August 2005 for about $300.
Consumers should take the recalled ride-on vehicles away from children immediately and contact the company for a free repair.
For additional information, contact Dorel Juvenile Groups Ride-On hotline toll-free at (866) 611-3022 between 8 a.m. and 4:30 p.m. ET Monday through Friday, or visit www.djgusa.com.
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC).
How do u charge a edelbrock power wheel corvette for kids 12 volt batteries and a 6 volt charger
Hello! Due to Charger Voltage Compatibility: Never use a battery charger unless the battery voltage matches the output voltage rating of the charger...Therefore do not use a 6-volt charger on a 12-volt battery and visa-versa...
guru...........
saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Battery will not stay charged
Could be a bad battery. If you know its not....Then it..
Sounds like something is drawing the battery down...The best test for this is.... Well before starting this test make sure your doors are closed and everything is off. Then ...Take (disconnect) one end of the battery cable, the Positive or negative it don't mater witch one. Put a 12 volt test light between the two disconnected (cable and battery end)...now if the light is lit, then you have a voltage drain somewhere...to find out were it is you will have too start to remove your fuses one at a time until your test light goes off...for example: if you pulled your cigaret lighter fuse and the light went off then you know there is a problem with that circuit...ect......
This sounds a little confusing but it is fairly easy..i sure hope this helps you out..Good Luck
1helpful
3answers
Need 12 V Battery- Corvette Yellow purchased at Toys R Us
Personally I'd buy another brand of 12 volt and just change the ends to fit in car. Measure dimensions of original.
2answers
Is there a way to drain the gas tank on a 1994 chevy corvette?
More than likely not, they dont install petcocks on fuel tanks any more, your going to have to drop the tank do drain it.
Cannot find relay center in 1990 corvette
check the low side switch located on the ac receiver drier for 12 volts if so jump it with a paper clip if the compressor comes on then the relay is good if not the relay is in the fuse junction box under the hood.Most likely the pressure sensor.
6helpful
4answers
Cant find a kid trax battery charger
Here 12V Battery Charger for Kid Trax Riding Toys Dodge Ram Dodge Charger... you can purchase the charger from amazon. I hope this was helpful. Have a nice day
Apr 19, 2009 • Toys
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
