The chain came off and I can get it back on however I am missing where to attach the chain tensioner restrain as the tensioner keeps hitting the gears and makes the chain came off again.
SOURCE: How can I put chain back on my E200 razor electric
First your going to remove the deck.
Take off the chain tensioner
Next remove the motor and put the chain around the gear
Put the motor back on the scooter with the chain on
Then take the rear wheel off and put the chain into the gear.
Put the rear wheel back on along with the chain tensioner and deck
Your done!
Note: the reason why I say you have the remove the motor and wheel is the get the chain on. So you may only have to partial remove the motor or tires to get the chain on.
SOURCE: re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
SOURCE: what do you do when ur razor e200 electric scooter
hi am [email protected] i have scooter E200 i wana fixet haw do you now som
one in sydne australia the fix scooter if yes call 0415781584 i wana fixet pleas thankyou
It is the tensioner "spring" that stops the tensioner arm hitting the gears. - thanks
