Hi peter, 1st id contact your phone provider most the time they can check your number an give ou the lock code, however if its a new phone (not refurbished) codes that have never been "set" can be 1111, 1234, 0000, but be very careful to many wrong code entries can lock your phone completely, hope this helps
SOURCE: LG CE 0168 phone security code Lock
have you left the phone off for 24 hours if you switch it on and it is asking for security code i can get the master override code for your phone but i need the imei number and the code number off the back of your phone under battery the imei is 15 or 16 numbers long might be like123456/44/22343/2 and then the other one is about 6 numbers long 123456 if you give me these i can give you master code if your phone dont ask for code then you need to get it flashed at a shop to unlock it hope this is some help
SOURCE: Unlock the U8330 LG Phone
for diffrent lg model, lg unlock codes are diffrent and also for diffrent gsm network unlocking method is diffrent. ths blog provide free lg unlock codes for diffrent models. below is the method for unlock lg c1100 from network.
C1100
Enter code into the main screen 2945#*1201#
Clear back to the main
screen
Go to the menu, then
Settings
Go to the Security
settings
Go to Sim Locks
Go to Network subset
Deactivate OK
Enter unlock code from
care and press OK
Phone screen will display
DONE
http://www.lgunlock.net/LGunlockinstructions.htm
thank you i found reset number here
plz inform and give some money me
[email protected]
Thanks for helping! But all it says (on the phone) is "Insert right SIM"?
