Televison & Video Logo
Russell England Posted on Nov 30, 2008
Sony KV-32XBR96S Wont power on,Just makes clicking sound
My problem is with the Sony kv-32xbr96s.When I turn on the tv,either with the remote or power button,all the tv will do is click real fast and eventually gets slower and finally the tv will start to come on and off but with a loud snow white screen,unti it finally stays on with a picture.Occaisionally it will do this throughout the day.I dont know what else to do.Is this worth fixing? Thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
175
Points
I have the same problem with the power button clicking on and off was there a solution? Is it worth fixing?
How do you fix a tv that wont turn on
sony MDL.KV-32FS210 Tv power light flashing,awaiting signal to come on. neither tv or cable remote wont turn on tv, manual button has no effect. I assume relay inop. Ther is no clicking as I normally hear.
2answers
My kv-20520 tv wont turn off closed captoining
Maybe you have to scroll through the Closed Captioning options or your menu for a bit until you find it and maybe you blew your speakers
2helpful
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Video Labels stay on - Sony TV Model KV-32V16
Press Display / ' i ' button TV original remote and on-screen display will disappear.
I repeat, you need Sony TV original remote to do so, universal remotes do not have such button.
KV-27FS12
hi there, there is a problem at your power supply section. do some test, it maybe a electronic part faillure. ty
2answers
Sony kv-34xbr800
I have the same problem. When using the remote, it makes the clicking sounds like it turns on, then immediately makes the clicking sound of turning off. The LED blinks repeatedly 6 times over and over.
I *did* get it to come back on by holding the power button down for about 5 seconds. Now I'm afraid to turn it off again! :(
3answers
Sony MODEL KV-2585 TV
You have your information incorrect, Q is not the designation for diodes, Q657 would be a transistor. First give us the correct number for the diode and how do you know it is shorted?
Sony KV-24LS35U green light flashing 11 times
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
