I recently moved into a home with a Frigidaire self-cleaning double oven model number FEB755CBS-B and I am unable to change the clock time. There is no button at all to change the clock time. The only button that exists is a button to set the time for the timer, the bake time, stop time, and clean time. Thanks so much.
SOURCE: Setting the correct time on the clock
If you could send me a picture of the control I can show how to set the clock for sure. Usually on frigidaire you will hold down on the clock button (may be a picture of a clock) until it blinks and use the up and down arrow buttons to change the time. When the time is set hit the clock button again.
SOURCE: frigdaire gallery stove
lock mechanism is acting up. happens sometimes. you can get to it from the back and get the thing open to use until you get the part
SOURCE: self cleaning oven
here is the link where you can download the owners manual for your stove.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200919en.pdf
you may have to copy and paste this into your browser. and it may take it a min to load.
please do not forget to rate and comment about your experience today on fixya.
SOURCE: Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
SOURCE: Frigidaire oven overheating
I would say that the oven thermostat is malfunctioning, and you will probably need a new one fitting.
Make sure the sensor inside the oven has not become detached, as this will make a differance.
Plz leave feedback.
Ta.
