Won't select record
(1) Make sure that the credit unit is not stuck and that all of the contacts open and close correctly while manually operating the solenoids. Lubricate it if the wheel does not turn freely. (2) Make sure that there are credits on the machine. (3) If it still wont select check fuses or (4) try pressing the letter and the number simultaneously, some "free play" set ups will work this way.
SOURCE: I just bought this Seeburg
the reject switch on the mechanism is stuck or bad its right next to the tone arm
SOURCE: Jukebox won't play selection, selects cd's 1-100 in order
Dear Amanda, Here is the manual,
Try re-programming your juke box per the instructions in the manual.
If you will e-mail me at [email protected] , I will E-mail you the 100 page manual in PDF format.
Gary.
SOURCE: seeburg jukebox sx 100 scans twice and returns
I suggest that you go to the following site for a solution to your problem.
The information listed hereis second to none.
http://home.pacbell.net/fmillera/
Regards
Alan Hood
ami-man
UK
SOURCE: Seeburg AY160 Spins as if record in place. will not reject.
Try removing the mechanism cover (power off). Turn it back on and try lifting the manual trip lever just to the right of the tonearm. This will cycle the mechanism. If it cycles but still won't engage and scan down the track, your clutch is stuck from lack of lubrication. Consult the manual, which you need to have. Try eBay - several people seel good reprints.
This is a common Seeburg problem and can sometimes be fixed IF you can get some oil into the clutch. Otherwise, you'll need to take the clutch tower off and that's best left to someone with experience.
IF you want to attempt it, you MUST have the manual as you'll have to set up and re do a bunch of adjustments after taking so much apart.
SOURCE: my seeburg disc jukebox skips a lot
try going into service mode to find the problem could be different things also you could try cleaning the laser this is one of the easy options
