Does it need to be done at installation point? Either way how do I do it
SOURCE: 3D Home Architect Home Design Deluxe 8
This program is not vista compatable, sorry. You will either need to create an XP partition and run it from there or use another product.
SOURCE: Home Architect
Hi shelley269,
I found the solution to "The procedure entry point _resetstkoflw could not be located in the dynamic link libray msvcrt.dll."
To do this:
1. Right-click on the START button.
2. Select EXPLORE.
3. Click on the + next to C:\Program Files.
4. Double-click on SIERRA.
5. Double-click on the SHA folder.
6. Find the msvcrt.dll file.
7. Delete it.
Rcouto
SOURCE: 3D Architect and 3D Landscaper are not running with Windows Vista...
if your problem is the installation in Windows Vista--> Try to use this sw in Compatibility mode--> Desktop--> right click on the program icon--> Properties--> compatibility--> select Windows XP or other older version
SOURCE: I would like to install 3D Home Architect 3.0
1. Change the Settings of the Program:
2. Copy missing dll's:
Hopefully this will help you too! Good luck :)
SOURCE: Can I make a older version of 3D home Architect ,,
no because drivers is in every windows some will work and some want.
