How do I get my home made movies onto my tv from my htc amaze 4g. what menu? or setup do I have to do?
SOURCE: my evo 4g will charge
The problem sounds to be with the USB port is partially damaged and not making connection fully with the board. There are about 4-8 connections on the USB connection and I believe only 2 need to be connected to charge the phone, but all need to be connected to communicate with the computer. I suggest you first try a different USB cable and then look for a local repair center.
I use Photo Tech CPR in NYC for all my repair needs. www.cpr-nyc.com
Good Luck
Paul
SOURCE: I just purchased a new HTC Inspire 4G cell phone
Thanks for visiting FixYa!
Just a note:
HTC Sync cannot be used for file transfers of music and videos.
To do that, you need to remove your phone's memory card - insert it in a PC - download the Music/Videos to the PC - then transfer them to the memory card.
SOURCE: How do I connect the HTC EVO 4g docking station to
Your TV needs to have an HDMI or USB plug to be able to do this. Most TV's made since 2008 have an HDMI slot. I'll attach images of both an HDMI and USB plug to show what they look like. Plug the HDMI or USB plug into the slot in the TV and the mini plug into the docking station, then dock your phone. You will need to change the input on your TV to display your phone on the TV.
HDMI: http://fplanque.net/Blog/Content/dev/electronics/hdmi.jpg
USB: http://www.bidanswer.com/uploadfiles/USB(1).jpg
