HTC Chacha Smartphone Logo
Posted on Jun 09, 2012
Having problems with the keyboard on my htc chacha, when i press any of the buttons down the right hand side i get a 'P' come up on the screen or it send blank messages.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
590
Points
Having problems with the keyboard on my htc chacha, when i press number 4 the message are directly opened & i cn not complete my call
5 Related Answers
billa vimal
vimal raj
  • 64 Answers
  • Posted on Jul 26, 2009
SOURCE: how to send a text message on a htc touch pro shattered screen
there is no way out other than getting your display corrected..
Anonymous
  • Posted on Sep 14, 2009
SOURCE: Problem sending SMS with HTC G1
i cannot send sms using htc g1 mobile
Anonymous
  • Posted on Mar 20, 2011
SOURCE: there is a symbol on the top right hand side of my
Phone speaker is mute.turn up phone speaker on left hand side of the phone.
Anonymous
  • 76 Answers
  • Posted on May 01, 2011
SOURCE: htc ozone (xv6175) will not
Obviously one of your applications that you installed is the problem. Your best bet is to try to hard reset or reflash your device.
To do a hard reset:
  1. From the Today screen, press the left soft key to choose Start.
  2. Select System Tools then press the center of the 5-way navigation pad.
  3. Select Clear Storage then press the center of the 5-way navigation pad.
  4. Select Factory Default. Enter 1234 then press the left soft key to choose YES.
Anonymous
  • 43 Answers
  • Posted on Jun 06, 2011
SOURCE: I can't send video messages on my HTC Inspire.
Open up your video camera. Change the settings so that it is set for MMS. It will decrease the resolution so that it is able to send. Good luck!
How to reset htc chacha cell when it is demanding email &p/w rejecting
Performing a factory reset using hardware buttons If you can't turn HTC ChaCha on or access settings, you can still perform a factory reset by using the hardware buttons on HTC ChaCha.
  1. Remove the battery, wait for a few seconds, then reinsert the battery.
  2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
  4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
1helpful
Forgotmy password on htc chacha mobile phone
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Lcd problem
replace screen.
My Htc Chacha's lcd light keeps flickering on & off it wont charge what does that mean ?
Sindia, this sound me software problem, when your device has a software problem it wont charge or start at all normally, so try to hard reset but this will delete all data for hard reset follow the instruction :
1. Switch off device;
2. After 3 min, Press and hold volume down button and power on button once it shows 3 android images appear leave the buttons and press volume down to select a clear storage, and then press power and then press volume up to start the factory reset. after this process your device wil reboot and start normally. now your device is ready to use. Best of Luck.for further help post comments.
Source :
http://www.hard-reset.com/htc-chacha-hard-reset.html
11helpful
Htc chacha wont turn on and orange light flashing
The battery is completely dead, charge for about 1 hour; if flashing light continues then you need a new battery, I've just done this to my phone..
3helpful
My HTC Ozone is locked up again. cant even get it to start up. what do I do?
Step 1: Power down the phone. If your phone is already powered down, you may skip this step. Note: Removing the battery, while technically powering down the phone, is not the correct method to make the following steps work.
Step 2: With your left hand, press and hold the VOLUME DOWN button that is located on the side of the phone. Continue pressing the VOLUME DOWN button and press the SEND button. With both the VOLUME DOWN and SEND button pressed, use your right hand to press the POWER button.
Step 3: A gray screen will appear asking you three options. Pressing the VOLUME UP button on the side of the phone will be the correct option to hard-reset your phone to ROM default.
Step 4: Press SEND to verify choice.
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
