Plug accidently left in skimmer basket so pool pump basket was half full of water and it ran like this 8-10 hours ........running low psi of 5 and making a slight grinding noise
Your pump should be just fine once the water starts flowing again. You may have run it too long without enough water to cool the seal.
If it is leaking water between the Jacuzzi Pump housing and the motor then you will need a new pump seal. Those are common pool parts.
Rod
US Parts Center
888-521-6183
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
