My hour meter is showing error, not the hours. I used the mower, it had 54 hours on it and then the next time mowing, I looked and it read ERROR
SOURCE: trouble code ch6 oil on hour meter
SERVICE REMINDER/HOUR METER
Service reminder shows the total number of hours the engine
has run and flashes to indicate that the engine or mower needs
servicing. When service is required, the service reminder will
flash for two hours. To service engine and mower, see the
Maintenance section of this manual.
NOTE: Service reminder runs when the ignition key is in any
position but “STOP”. For accurate reading, be sure key remains
in the “STOP” position when engine is not running.
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: mower keeps cutting off
my brother had the same problem with same mower. he took it to service station new plugs etc. still did it he took his back maybe problem with the magneto/ coil since you only have 12 hours on it, take it back and get a different make ie john deere or cub cadet husqvarna riders are junk!!!!!
