SOURCE: Lawnmower loses power when I engage blades
This is most likely a belt problem. Check the deck drive belt that runs from the mower deck to the engine it/s come loose and got stuck between the guides.
SOURCE: Lawnmower looses power. Sounds
Hi, first check the oil. If it smells like fuel, change the oil. Secondly if oil smells ok, check the valve clearances and adjust if incorrect. Let me know if the oil smells like fuel and I will help with a fix to stop it happening again. Regards Phil.
