My tv said when i connect the xbox360 , "Connect" and after few seconds "no signal". im trying to connect my xbox to other tv. and the xbox worked fine. im trying to replace cable. but the problem is not resolved . i have LG47LE5500. (xbox worked fine on other TV , and all the connections work). (The xbox worked fine on this TV , Suddenly stopped working)
Try different AV ports on the TV, if it doesn't work press the right trigger + Y, right after the console starts (this will reset the resolution of the console output) I'm assuming you are using the same cable that worked with another TV, so neither the cable is broken, neither the Xbox. It can only be an output format problem, bad configured or a faulty TV.
SOURCE: HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
SOURCE: connection of xbox360 to sony bravia kdf-e50a12u rear projection tv
http://www.avforums.com/forums/showthread.php?t=384717&page=8
3/4 down the page it tells you how to fix it
SOURCE: cant connect xbox360 to hotel wireless router
hotels have a special program for routers creating their own community network, you have to access that through a link on the computer and you cant do that through the xbox. the hotel fucked you
SOURCE: New XBOX 360 no picture / sound
I have 360 xbox. I switch to hd and have no picture or sound.
jb
