On the end of the wire it should be labled what it is ie power sw or hdd led. look on the mother board with a magnafying glass the connecting point will be labled it will be near the other connectiions
You really don't need the lights your comp will work 100% the same way, but if there is only two spots missing then you plug them in there, it is usually the white wire on the left, and the green wire on the right with the words "power led" facing up towards the power supply
The correct wiring plan for this computer is as follows:
Pwr Led Pwr Sw N/C
X X X X O
X X X X X
HDD Rst N/C
Note : N/C = no connection, top row has no pin, bottom row has a pin but not connected.
when you plug in the Pwr Led and HDD connectors, a light should come on, if it doesn't , turn off the pc and turn the connector round on the pins, re -power on your pc.
my emachine has three sets of wires each one has two colors. green/white -power led, red/white-hdd led last black/white- power sw in which order do they go
