What are compression specs for briggs 12.5 hp mower engine?
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
SOURCE: No spark at plug
Hi, I can see you posted this in April, so you may have sorted it by now!..? Is your problem that it will not start? If so and you have checked that the air filture and spark plug are OK, then you should make sure that all four lights are on, on the dash. Also you need to make sue that the black flap at the back directly behind the seat is pressed down properly. If it is up slightly it will stop it from starting as it is a safety feature. It has some sort of trip swith on it. I hope this has been helpful.
SOURCE: 17 HP Briggs & Str lawn mower engine that is smoking a lot -
compression test it can either rent or buy one should be over 90psi!!!
SOURCE: rally ride on lawn mower not starting. briggs and
i have a rally lawn tractor when i hook up the battery it wants to start key is off only thing i did was change the belt. was working fine before .
SOURCE: 24 hp Briggs Stratton sears
If the mower starts and continues to run after injecting, you may want to make sure the choke is working properly. If the choke plate is not closing all the way, it will make cold starts difficult.
Testimonial: "thanks for the help the choke was open just a little"
21 to 1 whats the total pressure
