Try to charge it but when I connect it to pc the charging, red light brights around 20 seconds and the light turns off... What can I do to charge again. Thanks for help...
Mine was just doing the same thing, changed to a different cable and it's fine now.
I dont unserstad what is going on ,may be someone will help me to solve my problem, i connect to "charge" then it wont turn on its really weird i dunno whats going on i dont see the "flash" blue light wich indicate that everything is fine or nore do i hear the startup music from "headset"
SOURCE: Headphones has red light
Hello, I believe I just figured out the solution to this problem. I was experiencing the same thing, and as I was just showing my friend the problem I noticed that the green light came on after I turned on the music on my computer.
So, after removing the headphones from the base, the green light will come on only if there is sound playing from the computer (It takes a few seconds to turn on). It seems like they should have mentioned this somewhere in the manual...
SOURCE: the operating instructions say that after 16 hours
I have the MDR-RF970R but I bet the battery is the same. If you have had the headphone for seceral years then I bet you are right, the battery is going. You might try using them till the battery dies and then recharge. This is called deep cycle and may time it will extend the life of rechargables.
If the headphones are new, then just check and make sure that they going all the way into the charge slot.
I will say it is not common for me to see the light off, but I use the headphones all the time.
Good luck.
