Two months old Razor MX350 DIRT ROCKET - BLUE, started strange charging problem, red light even after 24 hours of charging (a week long, now turns green after just 10-15 minutes of charging (sometimes instantly). But the speed and battery backup has become less than 10% what it used to be in the first 45 days of purchase. Please HELP.
Have a read of the trouble shooting guide here,
http://www.razorama.com/razor-installation-guides.html
It sounds like a fault with the charger. Test the charger output with a voltmeter to confirm correct operation. IF OK then check the wiring , fuse, switch conections between the charger and the battery.
wiring diagram is here http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
SOURCE: My boys have not rode
The battery went bad inside the bike. I would take it out and go to batterys plus and they will help you pick out a new one
SOURCE: Battery shows a full charge but wheels won't turn while grounded
theres nly 2 things at work here in my opinion, the battery and the charger, if this bike is of any age chances are the battery is no longer good, it may read ok with the meter but when you put it under a oad like trying to ride it it may go to 0000 see if you can mete it under aload
SOURCE: I charge it forever. But the charge indicator
You have to let it charge for as long as it takes. If it does not charge in 36 hours, then look for a new battery.
SOURCE: Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
