Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
How to connect on 220 volts al the wires on hayward super pump
6ya staff
SOURCE:
john224
John Prohaska
  • 1378 Answers
SOURCE: wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Posted on Jun 13, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: my hayward super pump has a wiring diagram but it
Is one screw silver and one brass? Or are they both silver or both brass?
Posted on Aug 20, 2009
poolyoda
  • 128 Answers
SOURCE: Need wiring diagram for Hayward dual Super 2 speed
You need 4 wires to wire the 2 speed pump. You will also need a 2 speed time clock.. Tightwatt or intermatic. The wiring diagram is on the motor.
Posted on Aug 30, 2009
john224
John Prohaska
  • 1378 Answers
SOURCE: I am installing a Hayward Pool pump max flo II at
Either one. Neutral to the other post. Be sure to set the voltage change device to 115V to match your incoming line voltage.
Posted on Sep 15, 2009
Testimonial: "That's outstanding info for anyone installing a pool pump. Tom Smith"
A Miller
  • 8404 Answers
SOURCE: I'm need assistance wiring my hayward 2 speed
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
Posted on May 25, 2010
Hayward super pump wired to switch diagram
sounds like 220 volt if using a switch must be for 220 volts usually pumps wired for 220 volt blue wire to one side of switch terminals then new wire to pump L1 lug the other side of switch gets the red wire going to other side and new wire to pump from switch to L2 and green to case or ground make sure motor is wired for 220 volt on back
Dec 06, 2017 | Pool & Spa
I burned up a 1 1/2 Super Pump. I see it was originally wired for 120 and am wondering if I should wire it for 230 with my new pump. What are the advantages/disadvantages of 230 vs 120v.
120 volt carries a higher amperage through the circuit, while 220 carries a lower amperage through the circuit. Safety and wiring sizes come into play here. 230 will always be better over 120 for the above reasons, and also for the fact that it is more cost effective on your electrical bill.
wire your circuit and your pump for 220volt if possible. Only use 120 volts if you have to do it and theres no other options.
Apr 13, 2011 | Hayward SUPERPUMP 2.0 HP, 115/230V
How to install hayward motor?
Just the motor? Three things you must consider: There are 4 bolts that fasten the motor to the pump housing. You need to determine 110 Volts or 220 volts - 220 will run the pump more efficiently. Bonding. Your motor must be bonded to all other metal parts of your pool system.
Aug 22, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Can you please tell me the correct wiring for a Hayward 120V pool pump (not 240V) Thank you
Follow diagram on the tag. typically low voltage and high voltage volt are diagramed on the tag. Most manufactures send pumps out already for 220. the A and B terminals are for pump wires. and the lines are for the power cord. follow the diagram and you can't go wrong;
The Pool Tech
Jul 10, 2010 | Hayward 1HP Super Pump II Inground Pool...
If you are replacing a 2 hp pump with a Hayward 2 hp super pump on a 220 line is L1 white and L2 black
Shouldn't be a white line on a 220 circuit but some people use them. Red and Black is the standard. If you are sure they supply 220 VAC, which I would verify, it doesn't matter which one goes to which terminal. 120 or 3 phase matters. If you have a multi meter, put the red lead on the black wire and the black lead on the white wire. If you read 220, good. If you read 120, it will make a difference.
Jun 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
Looking for a diagram on a hayward pool pump electrical wiring model super 11
What specifically are you looking for (beside the fact you asked for a diagram)?
It should be setup for 220 Volts ... the only thing inside is a start cap.
Can you tell me more? I maintain 5 2 and 1 1.5 hp such pumps.
Oct 14, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
I am installing a Hayward Pool pump max flo II at 120 volt. I have 2 connections L1 and L2. Which one does the black hot wire go to.
Sep 15, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
41 people viewed this question
Top Hayward Pool & Spa Experts
Bill Jordan
john h
US Parts Center
US Parts Center
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
