Question about HP Pavillion ZV6000 Notebook
Hp g60-235dx notebook screen flickers - HP Pavillion ZV6000 Notebook
  • 470 Answers
This can be caused by a few things. One the heat computer gets hot and flickers. Suggestion: Clean laptop of dust and debree at the internal level.
This can be caused also by a video card which got hot and cracked the solder weld on the internal chip. This is a problem for most laptops when they get hot. There is several places that redo the boards for a fair price. There really is nothing you can do about that accept to replace the board or have it soldered over again to seal up any cracks. The way to tell is hold the PC with both hands and slightly bend it back and forth and see if it shorts out clears up or blinks.
Third this could be also caused by the video cable came loose of if it was dropped it may have jarred the cable plug. The way to tell if that is the case is taking it apart and cleaning the cable input plug with dissolving alcohol and a q-tip wait until dry and re plug it in.
One of the capacitors could be damage or bloated and needs to be replaced. You can also replace the screen as well. So as you can see there are several possible causes for this issue. I would recommend taking it in to a good shop and have them diagnose what is going on with the video or screen. Messing with it without experience can lead to serious damages if you do not know what your doing. Thanks for asking John
Posted on Jun 07, 2012
SOURCE:
Notebook screen flickers
looks like your fl inverter may be going bad
Jun 07, 2012 | HP G60-235DX Notebook
Hp pavilion dv5, flickering screen problem mostly when 26" external monitor is connected, Using Windows Vista 32bit
First restart the computer and tap f10 key on keyboard to enter bios, and check wethere the screen flickers or not you can even try to tilt the screen and check as the drivers doesnt works in bios screen ... if the screen flickers then it is a hardware issue .. if it doesnt then log on to safe mode with networking by pressing f8 as the notebook restarts and then go to device manager by typeing device at the start search and the uninstall the video driver and then reinstall it from hp.com support and drivers ..issue will be resolved if not then do a bios update from hp.com, support and drivers.
Apr 29, 2010 | HP Pavilion DV5-1000US Laptop
HP HDX 16 laptop
check in the bios
if it flickers on the bios then needs to send the laptop in for a repair....
if it does not flicker in the bios then needs to
1> update the display driver
2> perform a recovery
regards
DJ
Mar 16, 2010 | HP Pavilion zd8000 Notebook
How to solve laptop nx7300 screen flickering
sir try un-installed your video card then install angain.
Feb 22, 2010 | HP Compaq nx7300 Notebook
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 19, 2009 | HP Pavilion dv4000 Notebook
Hi my ho nx9005 laptop screen keeps flickering
you have a problem with your flat it is a cable connecting the monitor to the notebook itself and may be damaged or not fixed in it's place
Oct 26, 2009 | HP Computers & Internet
HP Pavilion dv2000 Screen Flicker
Please replace the screen for optimal performance.
Do rate this.
Feb 25, 2009 | HP Pavilion dv6000z Notebook
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Flickering monitor attached to notebook.
doe syour lcd screen have pc input or dvi > also in your nvidia control panel u nee dto tell it add 720 p tv outto display manger always 60 hertz try differt resultion 1024x 768
Jan 10, 2008 | SPARKLE Computer GeForce 6600GT, (128 MB)...
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
Nov 21, 2007 | HP Pavilion zd8000 Notebook
HP Pavillion ZV6000 Notebook Logo
152 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
