The most likely cause is the inverter board located just below the screen behind the bazel, go to www.ebay.com type make and model of laptop, refine search to inverter board. The second less likely problem is the backlight behind the LCD display, [built in]
rumors on the internet or infinite, endless and wrong.
what can go wrong with 3billion transistors, and 17GB of windows files.... endless. (Rhetorical question)
forget all that. please.
what OS? you didn't say what windows it is>?
any modern web cam will work (not XP)
any mic for a PC works, its just a simple mic.
if in a hurry, got to any PC store. BEST buy? (i tossed a coin)
walk in say have DV7 laptop with windows 7 ( or what it is)
then ask for headphones or one onces with boom mic.
like you see vast folks do with SKYPE.
if PC is XP windows, good luck finding things that work
but you can. XP is dead now for 3 years.
Then choices are endless on all parts.
head phones
mic
CAM.
endless to the extreme.. CHOICES
thanks for showing the 200. G60t-200. they made lots of 60s.
the fan on all PC's need to be cleaned every year
or they all pack up and overheat or make noise.
if the the fan, free of any lint makes noise (not blow sound)but
racket, sounds, the bearing inside are shot.
no fan made lasts for ever,
but longer that the HDD, and batteries, for sure.
but way less the 20-30years or more for CHIPS.
its just a dc brush motor with bearings.
some are AC motors inside,(with 3 phase driver inside and no brushes, fancy) but is of no matter, noise bad is bad fan.
its really that simple.
keep in mind folks in text box can not hear your bad fan.
so answers will be, wrong, 1/2 the time. here.
due to , all work like this is hands on ears on eye on job and lots of experience.
if the blades are free ,of JUNK.
and it makes bad sounds, its bad. simple as that.
except in the cases of its falling out , screws missing , or loose.
like I said I cant see it.
Which version of Windows are you running? It sounds like you may need to reinstall your operating system. It is fairly simple to do this with windows xp without losing everything you have saved and installed.
