Please help I'm a Graphic Designer and all my stuff is there!!!
Try connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
SOURCE: how to use hitachi simpletouch external 320gb hard
Hello
If the HHD gets power and you can feel the drive spinning, you can try these steps and see if your problem is solved. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
If you cannot see any power light flickering or feel movement on the drive when you power it up, then there is a other problem. Hope this can help you.
Best regards
Andrea
SOURCE: Hard drive isn't recognized
Great advice tech8 !!! That worked for me. I was frustrated with this problem for the last month. It looks like my chief problem was that the drive letter previously being used for this HDD was assigned to a different network path. It looks like it didn't automatically give a new drive letter. Your solution worked great!
THANK YOU!
JR
SOURCE: Hitachi External Hard Drive (500GB) Beeping sound
Probably not. You can try putting it in the freezer overnight (in a bag please, don't get moisture in it) but most likely if you must have the files back it will take professional help.
SOURCE: Computer doesn't recognize my external HD
Test the HD on a different computer, if you get same problem, then the
disk can be faulty. Backup your data ASAP, then replace either exernal
hard disk enclosure, or the hard disk drive, depending on what is
faulty.
If you get no problem on other computers, then the
system is causing the problem. In that case try doing a system restore
to a recent date before the problem started. If that does not work,
then you will have to reinstall the system.
SOURCE: Hitachi 250GB external hard drive on Mac OSX problem
try to format it in other way like ntfs or fat32....
the lifestudio mobile is not recognized by the computer
