SOURCE: how do i operate the fisher price geo trax toys i
You're supposed to have a remote control that will send commands to make the train go.
SOURCE: I have a geotrax train that is not responding to
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets **** and hitting it will get it going. All three engines are working now.
SOURCE: GEOTRAX REMOTES ARE NOTE COMMUNICATING
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets stuck and hitting it will get it going. All three engines are working now.
SOURCE: I replace the batteries in the remote control and
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine.
• Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries.
• Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten.
• If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
SOURCE: Where do the bAtteries go
Here's the instruction manual: http://service.mattel.com/instruction_sheets/R2436-0920.pdf
It's difficult to tell without seeing it in-person but it appears to be on the main unit, probably on the bottom. Look for the battery cover which will have a phillips head screw. You'll need a screwdriver to remove it and insert the batteries as specified in the instructions.
go to the Lego.com database
http://us.service.lego.com/en-GB/BuildingInstructions/default.aspx
Type the reference of your set (7597) in the quick finder box
Submit
Select the exact instructions you need (US or Europe paper size)
Happy Download!
