Also the only effects that work are 87-99?
SOURCE: alot of the effect on the kaoss pad do not work. but for example effects 90-99 work just fine?
The kaos pad is a mainly input based machine ... You sure you got sound going in?
SOURCE: Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
