Underneith threads are really gunking
Are the thread with loops?
are the threads bird nesting?
try changing the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the machine top & bottom
Instructions:
1.) Set up your sewing machine on a table with good lighting available. Plug in the electrical cord.
2.)
Thread your sewing machine according to the manufacturer's directions. This requires slipping the thread through various retaining and tensioning loops to allow for the proper drag while sewing.
3.)
Wind a bobbin with the thread that you intend to use. You may have to partially unthread your machine to do this.
4.)
Cut a scrap of fabric from the fabric you intend to use for this project, at least 12 inches long and 4 inches wide. Double the thickness of your scrap by folding it in half lengthwise.
5.)
Sew more seams on your scrap, stopping to check your thread tension for your stitches until you have stitches on top and on bottom with no discernible looseness.
Complete details are available here.
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
SOURCE: singer 132q sewing machine
I wanted to turn my daughters old jeans into shorts since they still fit, but were too short. I was having the same problem, but I was able to make some progress. I switched the thread from a poly/cotton blend to 100% polyester and it was a big improvement. I still was unable to stitch through seams. I am going to try a more heavy duty polyester thread and an upholstery needle (18/110).
