Garden Logo
A
Anonymous Posted on Jun 06, 2012
Need schematic for ryobi x430 trigger
I need a schematic on trigger part for Ryobi 4 cycle x430 weed eater
Jim Parker
Level 3:
  • Master 1,041 Answers
  • Posted on May 29, 2016
Jim Parker
Master
Level 3:
Answers
1041
Questions
5
Helped
536574
Points
2636
5 Related Answers
Anonymous
  • 1126 Answers
  • Posted on Aug 23, 2009
SOURCE: need to know how much oil to mix with gas for a 4
You only need to mix oil with gas when it is a 2 cycle engine. 4 cycle engines run on straight gas. Since you didn't post your model number, here is a site you can hopefully find your owners manual at. Hope this helps.
http://odref.com/pdf/Ryobi/
Anonymous
  • 279 Answers
  • Posted on Oct 08, 2009
SOURCE: I have A ryobi 725r 31cc weed eater with a
Go to any auto parts store. Tell them what you want. They will be happy to help...Lee
mickey813
mickey813
  • 472 Answers
  • Posted on Dec 08, 2009
SOURCE: ryobi petrol weed eater
SOUNDS LIKE YOU MAY NEED TO REPLACE THE FULE LINES THAY DO GET BAD OVER TIME
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Jul 10, 2010
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
#1 Taper
Jim Parker
  • 1041 Answers
  • Posted on Aug 08, 2011
SOURCE: My Ryobi 2 cycle weed eater will run when choked,
I have a couple of Tips that will solve this for you:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
Good Luck!
Jim
My Ryobi weed eater x430. 4 cycle. It will start but then dies. Any suggestions
Sounds like a fuel problem - have you tried using partial choke? At least, this might verify that you just have a fuel problem. The 4-stroke is not as temporemental as the 2-stroke, but worth checking a few simple things : Is there an obstruction in the fuel supply ? Is the fuel tank supposed to be vented - if so, is the vent blocked ? Is there some dirt in the fuel, leading to a blocked jet in the carburetor ? - if so, drain/empty the carburetor, clean sediment & ensure all jets are clear and refill whole system with clean fresh fuel : If the carburetor or any part of it is loose, there might well be an Induction air-leak ( which could impair the engine's intake of fuel ) : And (of course ) - Is the spark-plug badly "gapped" or fouled ? Try to isolate and eradicate in a methodical way, good luck !
How to start a Ryobi s430 4 cycle weedeater?
I have a husky 4 cycle I have to choke it and it is a bulgar to start once I get it running it runs like a champ just make sure you check your oil first
How do I remove camshaft from Ryobi x430 4 cycle weed trimmer
The camshaft is hydraulically pressed together and impossible get apart without specialized tools. Considering the cost of the short block I would just replace the trimmer.
2answers
Oil pours out of its carburetor as it runs. How can I fix it?
This question refers to a Ryobi X430 4 Cycle Gas Powerhead Weed Eater and not to a leaf blower.
Apr 05, 2015 • Garden
1helpful
I am looking for a Ryobi weed eater manual. Need to know how much oil to put in my weed eater. Can you give me an answer or where I can get a free manual. Thanks
You did not list which model Ryobi you have, however...
If your Ryobi has a silver or black shaft, then it is an older model and requires a 32:1 fuel mix. In the USA, that is 4 ounces of 2 cycle mix per gallon of gasoline. If your Ryobi has a yellow shaft, then it was made by HCP and uses a 50:1 mix or 2.6 ounces of 2 cycle mix per gallon.
Sep 23, 2010 • Garden
Need to know how much oil to mix with gas for a 4 cycle ryobi weed eater
1helpful
Do you use mixed gas for a ryobi weed eater??
Unless it has a tag or decal on it saying it is a 4 cycle then it uses mixed gas/oil at about a 50:1 ratio. Straight gasoline will freeze the piston in the cylinder in mere minutes.
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
