I'm assuming you have a TDS750. Fuser NTC 4 is broken. These NTCs are extremely fragile. I would recommend you call an authorized Oce/Canon service representative to replace it.
Error codes on Oce plotters, including the Oce Plotter 340, can indicate various issues. Unfortunately, I don't have specific information about error code "22552" for the Oce Plotter 340, as error codes can be specific to the manufacturer and model.
To troubleshoot the issue, you may want to consult the user manual or technical documentation for your Oce Plotter 340. The manual should provide information on error codes and possible solutions. If you don't have a physical copy of the manual, you might be able to find it on the manufacturer's website or by contacting their customer support.
In general, error codes on plotters can be caused by issues such as paper jams, communication problems, hardware malfunctions, or software errors. If the issue persists and you cannot find a solution in the documentation, it may be advisable to contact Oce's customer support or seek assistance from a professional technician who specializes in Oce plotters. They may be able to diagnose and resolve the specific problem you're facing.check;
This article is about two printer error codes, 22551 and 22531. These codes are associated with the OCE Plotwave 345 printer. The error code 22551 means that the printer has lost its connection to the computer, and the error code 22531 means that there is a communication problem between the printer and the computer.
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Developer Pollution. Basically it means the toner concentration is too low. Check to see if there is toner in the hopper by looking down with a flashlight. If there is, try restarting the unit. If there isn't, put only one bottle of toner in and see if it starts conditioning again. Do this up to two more times. If it fails, or goes to a another error, there could be a problem with the toner hopper or the developer unit itself. Call an authorized Canon/Oce technician for parts and service.
Developer pollution error. Check to see if there is toner in the hopper. Cycle printer power a couple of times. If that doesn't reset the error, you will have to call an authorized service provider.
