Mitsubishi VS-60609 60" Rear Projection Television Logo
Anonymous Posted on Jun 07, 2012
Tv mitsubishi vs 60609
La pieza que conecta de tarjeta a tarjeta con unos pines
Anonymous
Level 3:
Top Expert:
  • Mitsubishi Master 14,553 Answers
  • Posted on Jun 07, 2012
Anonymous
Mitsubishi Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718662
Points
48227
Por favor habla en English?
5 Related Answers
Anonymous
  • 121 Answers
  • Posted on Nov 07, 2007
SOURCE: my screen is turning colors
May it have been knocked about so the projectors are out of alignment, or may it have been standing next to a powerfull magnetic field?
It may also sound like a mirror may have become misaligned, since the top half is affected
Anonymous
  • Posted on Oct 09, 2007
SOURCE: Mitsubishi VS-60609 50in. Rear Projection
Hi did you find a solution my 60 " tv has a similar issue.. the green light stays on but nothing.. please help
alvaro martinez
  • 40 Answers
  • Posted on Nov 17, 2007
SOURCE: conversion defectuosa
como sabras existen diferentes tipos de STK´S y en algunos casos
la mayoria cuando son chinos no sirven, asi es que te recomiendo que te asegures que sean originales. algunos de los que vende AG o MASTER son chafas.
freetek
Steve Allison
  • 5569 Answers
  • Posted on Jun 19, 2009
SOURCE: No power on 2002 Mitsubishi VS-60609
You've mad the right decison; fuses can fail due to metal fatigue as they flex a little each time current flows through them of ceases but a 2nd fuse is unlikely to fail instantly. This indicates a true problem.
If you found the fuse, it was probably located on the main power supply board and this item has likely failed.
Look for an assembly number on that board and call a Mitsu service company and inquire about repair or replacement cost. Either one can range from ~$75 to $150.
It would be interesting to know if the fuse blew as soon as the unit was plugged back in or only when you tried to turn it on with the remote or power button on the set.
If it blew only by plugging it in, that power board is the culprit. If it blew as you tried to turn it on, it could be a failed 2nd power supply for the CRTs that is often located separate from the main supply where the fuse was.
About any E-tech could ferret out the which of the two is at fault so you might consider having a pro do the repair but if you know the failure sequence you might choose to gamble on making the decision yourself.
Good luck-
Anonymous
  • Posted on Sep 19, 2009
SOURCE: Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Necesito bajar mis fotos de mi camara m340 a mi pc
Usted deber?a haber tenido el software incluido con la c?mara cuando lo compr?. Encienda la c?mara. Conecte el cable USB (modelo U-8) de la c?mara a la PC.Use el programa Easyshare para localizar sus archivos de im?genes y subirlas a su PC. Si esto es lo que no funciona, tambi?n puede utilizar un lector de tarjetas. Si uno no se construye en su PC, usted puede comprar uno bastante econ?micamente. Inserte la tarjeta en el lector de tarjetas y se mostrar? como una unidad extra?ble en "Mi PC". Crear una carpeta en su PC, ?bralo y seleccione los archivos de la tarjeta (unidad extra?ble) y copiarlos. Pegarlos en la nueva carpeta. Estoy usando un traductor en l?nea para esta respuesta, as? que espero que pueda entender lo que escrib?.
Donde encuentro el codigo para desbloquear la radio de un honda 2003
Hay algunos lugares donde normalmente te dejan el codigo de 5 digitos que van del 1 al 7. En la guantera, cajon del copiloto,etc o como le llames. De no estar ahi puede buscar cerca del volante, deberia haber alguna pieza con cierre a presion que cubra fusibles o algo parecido. Sino esta en ninguno o anotado en tus papeles del auto te quedan dos opciones, si el auto es americano puede ir al siguiente link
https://radio-navicode.honda.com/ l
Te pedira codigo de serie de la radio y el VIN del vehiculo. Para el codigo de la radio, puedes verla desarmando la radio (opcion no recomendada) o que la misma radio te lo de (recomendada). Con el motor apagado y la llave en contacto apagas la radio, luego presionas los botones 1 y 6, manteniendolos pulsados enciendes la radio y te mostrara la serie en dos grupos de numeros, quiza tarde unos segundos en aparecer e intenta no hacerlo muy rapido (pulsarlos y encender la radio apenas los presiones) que puede que no reconozca el comando. Con el VIN y Serial te vas al link, llenas los datos de la pestagna GET CODE y obtendras tu codigo, es necesario que llenes el formulario ya que evita que si la radio es robada sea activada ya que si tiene denuncia te invalidara la accion. Si no te funciono, solo te queda llamar a HONDA, hacer que te comuniquen con el departamento de piezas, darles la serie para que te den el codigo, y si departamento de piezas, que el de servicios te cobrara por buscarte el codigo.
Tengo un acer aspire 5100 bl51 cuando la enciendo en la pantalla no aparece nada y esta toda negra no se que pudo suceder estaba descargando videos y de pronto se oscurecio la pantalla se escucho un...
Desconecta la bateria principal y Desolda una bateria chiquita que trae en la tarjeta madre (Posiblemente este debajo de la tarjeta Inalambrica).
Luego manten precionado el boton de encendido durante unos 10 segundos. Luego conecta todo y Listo. Ya que compruebes que te da Video le soldas nuevamente la bateria. Eso es Todo
Como combertir el coyote hunter a 11 metros
  1. Quite la cubierta superior de la unidad y busque las resistencias en la parte inferior de la tarjeta principal
  2. Desoldar, y saque a los que es.
  • Si usted tiene el modelo más nuevo con los Mosfet en que el uso esta conversión
  1. Quite la cubierta superior de la unidad y busque la fila de 15 pines en la parte delantera de la unidad. Desoldar el cable de tiro corto desde el 7. clavijas a los pines 11 y 12 (conectados entre si).
  2. Desoldar el puente de soldadura cortocircuito de los pines 11 y 12 de modo que son pernos independientes sin relacion entre ellos
Un cordial saludo, Tony
2helpful
2answers
Al encender mi camara Nikon S80 me aparece que la tarjeta esta protegida para escritura como lo puedo quitar
¿Por qu? mi c?mara de decir "tarjeta bloqueada" o "protegido contra escritura"?
Los conceptos b?sicos. De la misma manera que las grabaciones en casetes de audio y cintas de VHS pueden ser protegidos por la ruptura de la ficha poco en la esquina posterior, el material en una tarjeta de memoria se pueden proteger contra la que se sobrescriban. En lugar de una ficha para romper, protecci?n de escritura se realiza mediante un control deslizante peque?a en el borde de la tarjeta (frente a la esquina cortada). Antes de que la c?mara tomar? im?genes, es necesario que este control en la tarjeta cuenta con un micro en la c?mara, que s?lo lo har? si no es en la posici?n de "bloqueo". El control deslizante en realidad no hace nada dentro de la tarjeta, por lo que yo no lo llamo un "interruptor" a pesar de que parece como tal. Su ?nico prop?sito es que sea detectado por el micro en la ranura de la c?mara, y es la c?mara que se encarga de la protecci?n de escritura, no la tarjeta.
Diagn?stico. Obviamente lo primero que debe hacer es comprobar que el regulador no est? en la posici?n de bloqueo. Si la c?mara te da este error en la posici?n de desbloqueo, esto significa que el regulador no ha podido hacer funcionar el micro, o que el propio micro est? defectuoso, o tal vez que hay alg?n error de sistema de archivos con la tarjeta. Para diganose el problema, ser?a muy ?til si se pudiera tratar de dos o m?s tarjetas de memoria diferente en la c?mara y ver si s?lo uno, o todos ellos presentan el problema.
Si s?lo uno presenta la tarjeta de memoria del problema: En este caso, es claramente algo que ver con la tarjeta de memoria. Es el regulador desgastados, doblados o que faltan? Una barra de desplazamiento que faltan de protecci?n contra escritura de la tarjeta de la misma manera que el deslizamiento a la posici?n de "bloqueo" se. Hay otra posibilidad. Recientemente he descubierto que algunas c?maras que utilizan tarjetas xD-Picture Card tambi?n dan este error a pesar de que esas cartas no tienen ni siquiera deslizadores de bloqueo! Adem?s, algunos usuarios han informado de la fijaci?n de este error a formatear la tarjeta. Por lo tanto, creo que tambi?n es posible que el error puede ser fijado por cambio de formato. Antes de hacerlo, aseg?rese de que usted ha copiado todo lo que quieras de la tarjeta y luego utilizar "formato" de la c?mara funci?n para formatear la tarjeta. Te aconsejo utilizar la c?mara durante la funci?n de formato porque as? se garantiza el sistema de archivos correcto. Si usted utiliza su computadora para dar formato, usted puede f?cilmente obtener el equivocado. Sin embargo, si es necesario hacerlo de esta manera, ver qu? sistema de archivos est? actualmente en uso en el disco antes de empezar. Vaya a "Mi PC" y haga clic derecho en la unidad que es la tarjeta de memoria, y seleccione "Propiedades". Ejemplos de sistemas de archivos son "FAT" (probablemente FAT16), "FAT32" y NTFS, para asegurarse de que su formato se realiza correctamente, asegurarse de que usa el sistema de archivos igual que antes.
Si alg?n trabajo tarjetas de memoria, y otros no, o las mismas cartas de trabajo, pero a veces s?lo a veces: El control deslizante es muy peque?o, as? que es posible que el n?mero de personas que informar de este error se debe a la falta de precisi?n en los tama?os de fabricaci?n. Debe ser dif?cil hacer un micro que puede sentir una cosa tan peque?a. ¿Tiene una mejor marca de trabajo de la tarjeta? ¿Puedes soportar quedarse simplemente las mejores marcas, o los que trabajan m?s fiable? Como remedio de ?ltima instancia, podr?a intentar envolver una peque?a tira de cinta adhesiva sobre el control deslizante para aumentar su espesor, pero creo que esta es una soluci?n de riesgo. Hay un riesgo de que la cinta saldr? en la ranura y causar a?n m?s problemas, o que la cinta ser? tan espesa que la tarjeta de atasco en la ranura y que tendr? problemas para sacarlo.
Si todas sus tarjetas de memoria se comportan de la misma manera: En este caso, es claramente algo que ver con la c?mara. Podr?a ser que el micro se rompe, o hay alg?n error de software. Aunque es menos probable, vamos a cubrir el error de software de primera; por favor, encontrar la funci?n del "restablecimiento del sistema 'en el men? de configuraci?n y uso para todo claro. ¿Es bueno? Si no, pruebe la soluci?n de cinta adhesiva en el ?ltimo p?rrafo en la esperanza de que se trata de un tama?o o el problema en forma con el funcionamiento de la micro, pero si eso no estamos fuera de las opciones en realidad, m?s all? de la reparaci?n de dicho micro.
5helpful
2answers
ERROR SCANNER 22 EN IMPRESORA HP LASERJET ML1120 MFP
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
1helpful
2answers
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Mi satelite m35s-s149 no carga electricidad
Tiene que volver a saldar la pieza donde se enchufa el cargador, esta se llama charger socket en ingles.
El trabajo no necesita de partes anadidas, la pieza cuesta menos de un dolar.
Solo que el trabajo de saldar en la placa madre es bastante delicato. Seguro que hai puntos que no estan bien.
Claro que esiste manera de saldar con un conector externo, saldando los puntos en la placa madre a unos hilos, solo que esto va a ser un poquito feo.
3answers
ACER ASPIRE 5100
que era lo que estabas haciendo cuando paro de trabajar? yo tengo el mismo problema con la mia, y creo que halgo esta malo con el BIOS.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
