I have a Samsung DLP television that the video keeps going out on. I have already replaced the lamp. I worked fine for about a month then started acting up again. Any other ideas?
SOURCE: samsung hlp4663wx/xaa (after replacing the color wheel)shadowing
If the color wheel you replaced was the BP96-00674A, it would have come with the proper cca adjustments for that particular wheel. You must enter the service menu and reset the cca's for proper color.
SOURCE: samsung,model-HLP4663WX/XAA , bought in jan.
Had same problem. Bought replacement lamp. Worked for 6 weeks now I'm looking at replacing the ballast. TV turns of after 5 minutes.
SOURCE: samsung model # HLP5063WX/XAA 3 lights blinking
It can be the Lamp Ballast as well as the Color Wheel.
SOURCE: I have a Samsung Model HLP4663WX/XAA Tv
Hello ma'am, hi, looks like the tv has problems with the power supply board, parts inside get to fail slowly, those are likely resistors, and capacitors, and active parts like transistor gets to go leaking, eventually they will be permanently to fail. so have it checked by a tech guy.
SOURCE: Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
