Televison & Video Logo
Posted on Jun 06, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rca tv has unusable signal onit
Screen has unusable signal across it
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Jun 07, 2012
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409171
Points
4988
Hi, Check the cable connections to and from the TV.
Change the channels to see if there are others that are out.
If you are not using any cable company then you will still need a set top box to unscramble the digital signal. Good luck.
5 Related Answers
A
Anonymous
  • Posted on Sep 28, 2008
SOURCE: unusable signal
it was a fuse in the digital board i took it to an rca repair shop and had it fixed has been working great since
Anonymous
  • 23 Answers
  • Posted on May 02, 2009
SOURCE: I am having a problem with an RCA tv..unusable signal.
make sure that you have it set to the right input signal source and that your source is working properly. if so then yeah, you need to replace the fuzle modulator.
Anonymous
  • Posted on Aug 02, 2009
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
mpaint
Michael Painter
  • 36 Answers
  • Posted on Jul 23, 2010
SOURCE: My RCA L46WD22 TV turns on but there is no picture
This is a very common problem with these models.
The problem is a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
mpaint
Michael Painter
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
The problem is very likely a fuse that has blown, if the following is true:
No Audio at all.
1helpful
Rca entertainment series unusable signal
i think your rca cord is not functional. replace it with another one or fix the connections of your cord.
Rca unusable signal
Your TV could be on the wrong input source. if your using red/white/yellow cables look for an inpout button or source or even TV/Video. your tV has many inputs on it and you can only acess them 1 at a time, this allows you to toggle through the input sources and when you get to the right on you'll have picture and sound
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
2answers
42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Unusable signal notice appearing on screen. we
Are you in an area where the digital transition has occured? You may need a newer tuner www.dtv.gov to get one for free or almost free.
1helpful
2answers
RCA TV
my tv shows a black screen with words saying...UNUSABLE SIGNAL
Unusable Signal
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Unusable signal
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
