Your problem is in your DSP circuit. This what makes your different soround sound options.
Coil L921 which is located on the DSP board may have opened due to in rush current.
Check coil L921, if open, replace it with a new and improved coil.
The Onkyo part# is 231237M022R2.
mine just screams in earnest what can be
5v present at 921.3 in other coils and 2.5 v
Why did choke L921 burn out and what is the rated current it should be?
In the service manual on the circuit page 20, the inductance 22uH of them. And on page 6 is the recommendation to replace 2.2uH and where is it correct?
Can someone help. Repaired receiver ONKYO TX-SR602E (not working since 2008). Choke L921 Turned out to be in a cliff, so there was no 2.5V and 3.3V. These voltages go to the DSP, the memory and therefore the signal did not pass. I measured the current of the supply voltage of 5V to 2.5V and 3.3V - 340mA. Put the choke NL453232T-2R2J-PF (size 1812) from TDK to 380mA. It turned out to be more than the original recommended, but managed to get on the board. This fault is described in the service manual 7 page.
SOURCE: Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
SOURCE: new home theater setup- no signal at tv using onkyo tx=sr605
This might somewhat help. Today I went back .. I went HDMI out of the Cable box and DVD player into 2 of the TVs HDMI ins. The digital audio out from each, straight to the receiver and things are working ok. All speakers are working OK. Sound isnt as loud or crisp but unfortunately I found no other solution.
SOURCE: Onkyo Reciever TX-SR806 Losing HDMI signal.
I had the same problem with my xbox 360. I was able to fix the problem by disabling the Display Discovery setting on the xbox.
I have the same problem, sound comes out wheezing, just goes in direct and multcanal.
I tested coil 921 and passed current 5v, where can I buy this coil
