SOURCE: spy car alarm manual
Forget the advice on how to steal a car. It's pointless and does nothing to answer your question. I suppose alicantecoli is proud of his abilities (I used to be too, but I don't do that anymore), however he is a fool if he thinks a 2-Way alarm is useless. While it may only take him minutes to disarm the alarm (waaaaay too long), with a 2-Way system & GPS tracking it would only take me seconds to find it again. Or you could use the silent alarm feature, allow the car to be stolen and immobilise it in the middle of the road. Beside all of this, a simple set of relays properly wired to monitor the alarm system power status can turn those few minutes into an hour or two. Anyway, to your question.
The install manual for the (rebranded) Spy 2-Way Car Alarm is a pathetic chinglish translation printed on a single sheet. It would do you no good unless you have some experience with electronics, and a working knowledge of your car's wiring. That being said, here's the wire colours for you:
6-Pin Connector:
Purple : A/C
Brown: On
Yellow: Start
Red: 12v+
Black: 12v-
12-Pin Connector:
Central Locking - it depends on the type as to how you wire it...
Yellow: Nc
Y/Black: No
White: Com
W/Black: Com
Orange: Nc
O/Black: No
Brown: Flash Lights
Brown2: Flash Lights
R/Black: Trunk/boot release
Red: Siren
8-Pin Connector:
Red: Window roll-up
Green: Side-door + trigger
Blue: Side-door - trigger
Yellow: Engine cut-off
White: Acc
Orange: Foot-brake
Purple: Handbrake
Grey: Start-sensing
2-Pin White: LED
2-Pin Black: Temp. Sens.
3-Pin White: Shock Sens.
3-Pin Black: Microwave Sens.
These four plug in in this order: 2PW, 3PB, 2PB, 3PW
Inside the unit (under the sliding cover on the top) there are three jumper settings: Elec/Pneu CL, Lights Flash/No Flash, Auto-arm/No auto. The first of each pair is the default setting.
Hope this helps. That, honestly, should be all you need. If you do need more info, then please DO NOT TRY TO INSTALL THIS ITEM YOURSELF. As it says on the manual, "Install the system by a professional people."
Need installation guide for the SPY LT117 car alarm. Thanks
