SOURCE: casio tk2700 clerk
Turn key to PROGRAM mode.
2 SUBTOTAL (the display should now show 'P2')
Now type the number of the clerk to change e.g to change clerk 3, press 3 on the numeric pad.
07 SUBTOTAL
Now type the new name for the clerk using the alphabet sheet (usually under your other keysheet).
CASH
SUBTOTAL
Hope this helps. If you have any trouble, just let me know.
Mark
SOURCE: Programing a Casio TE-2400
if you could get the logo ready for the casio dealer
the size of the logo is
W384 H168 Pixcel
B+W only
give this to the dealer and they will pop it on for you
SOURCE: Programming Casio TE-8000f cash register
please download your programmers guide/manual from the below link>>
http://www.premiercash.co.uk/brochures/TE-8000_User_Manual.pdf
please rate this solution.
Thanks for using FixYa.
SOURCE: kitchen printer won't print
hi im josh in cebu phils. friend the problem is in your setting try to change the port being used. go to settings the printer config..the printer port usb, local, com. then number if it is in 1 2 3 or so on. choose default if you used the default one. good luck
