Question about Hitachi 60CX29B TV
Power but no sound or picture alot of the time
I have a 60" Hitachi Tv. It's 10 years old. I've been having problems for about 6 months. First it started that the picture & sound would come on for awhile & then shut off. Intermittantly, the picture & sound would come on & go off-at first it nly happened here & there. The power stays on all this time. Now, it has continuously gotten worse....sometimes the Tv won't come on for hours even tho' the power is on. It used to help by turning it on & off again & again, but that doesn't seem to make much difference now.I have comcast & go thru the VCR. I tried bypassing the VCR & also tried playing a tape thru the VCR during the blackouts. The VCR tape wouldn't show up(or the sound) on the screen either. The quality of the picture varies. Alot of times it has a bunch of horizontal lines especially right after it comes on...sometimes it is pretty good. Should I try to get a repairman in or will it cost too much? Is it worth it or should I just buy a new one?
  • 4 Answers
The fault you are describing sounds like what we in the trade call dry joints, basically where components are soldered into the circuit boards in manufacturing, the joints become brittle and crack thus forming a poor connection which can vary with heat. well worth repair may need a couple of electrolytics aswell but i could do the job myself safely for under £100.
Posted on Mar 08, 2007
SOURCE:
I have bought the biggest lemon in this tv than ive ever seen before..shortly after buying it, i had green swirly lines throughout the whole picture...had 2 repair guys out here,1 replaced the "mother...
Lamps have a limited life. They useually last 1000 hours or so. If the TV is on from 07:00 until say 23:00 every day, that equates to 60 days.
There is no such lamp as a "One time replacement lamp" as they do not last for ever.
The average life of a lamp is just about 6 months.
If the picture is cloudy is probably needs the optice cleaning. It is very fiddly and damage can occur easily so get an authorised Hitachi repair service department to clean it for you. It should be carried out in your home and will take less than an hour. If anything gets broken, it is not your problem if they are heavy handed.
Hope that helps.
Feb 03, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi ultravision projection that is turning off
Ur tv projection bulb,been a long time had not been replaced?If the the bulb been,replaced the ballast might be dead.
Apr 14, 2010 | Hitachi UltraVision 55HDS52 Television
Flashing green light
The TV is on protect mode. This happens when an internal fault is detected. Start leaving the TV unplugged overnight. This will drain power discharging capacitor and internal circuits, and sometimes can solve minor problems. If the TV still does not start , it must be taken apart and tested. Parts that commonly fail are the PSU, controller board, low buffer and sustain boards. If the TV is only 13 months old, then it is worth calling Hitachi and asking for a warranty extension or a discounted repair. Regards.
Jun 04, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
Will not turn on 15 years old
i was watching tv and the tv just went dark. No bad weather. The tv will turn on but no picture or sound. please help asap
Apr 21, 2009 | Hitachi 60V500 60" Rear Projection...
Phillips 60 in. rear projection approx. 10 years old
This is a common problem with the older models. The opt chip fails. You can get a repair kit at www.magnavoxhelp.com. After a few months of getting smaller and smaller the audio and video will go out but the power light will remain lit.
Aug 18, 2008 | Philips 60P8341 60" Rear Projection...
No picture or sound, just blinking power light
Hi...I am sorry to say that I had this exact problem. It ended up being the upper and lower panel drives. I contacted Hitachi and even though my unit was out of warranty, they agree to pay for parts. I paid for labor myself, and it cost me $199.95.
Good luck with it...let me know how it turns out for you.
Aug 10, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Hitachi 32 No Picture or sound
if you are hearing a click and electrical statics when you try to turn it ON, the flyback of the tv is busted there are alot of reasons for that problem lighting is one so dont leave the cable screwed in if ever youre going out for a long time. you can have it replaced by a technician ( flyback). but it would cost you. and im not sure if you can find an orginal flyback considering its 10years old. there are replacement flybacks but quality would not be as good as the original one.
Oct 06, 2007 | Hitachi 32UX51B 32" TV
Hitachi-picture goes out but can still have sound
If it is a Hitachi 60V500 LCD projection TV, then I would suspect the lamp being the problem.
Feb 02, 2007 | Hitachi 60V500 60" Rear Projection...
Hitachi 60CX29B TV Logo
78 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
