Insert a movie and play it automatically In PowerPoint 2003, you can run your movies full screen. This is a very excellent feature.
- On the Insert menu, point to Movies and Sounds, and then click Movie from File.
- Click the video you want to use and then click OK.
- Tips: Always put the movie in the same folder as your PowerPoint presentation. If you later move the PowerPoint presentation to another computer, copy the movie too. Keeping your movie in the same folder as your presentation ensures the link will still work. However, you should always test the movie on a new machine just to be certain. Re-insert the movie, if necessary.
- After you click OK, you' are promoted with a message asking how you want the movie to start in the slide show.
I recommend choosing Automatically even if you want the movie to play when clicked- I will talk about how to set this part too. (If you choose when clicked you have to click the black box to start the movie. Because I don't like to show the black box on the slide, I do this a little differently.)
- You should now have a small rectangle sitting on your slide.
- Insert a movie using a file on your computer or in another location, such as a server.
- The movie appears as a still frame on your slide.
The trick I use is to move that rectangle off the slide, so it is sitting next to it, but not on it. You can size it down if you like. Click the movie (that is, the rectangle) and then drag it off the slide.
Play the movie full screen
- Right-click the movie object (the small rectangle) and on the shortcut menu, click Edit Movie Object.
- The Movie Options dialog box appears. Under Display Options, select the Zoom to full screen check box, and then click OK.
- If you want your movie to play automatically when you advance to this slide, you can stop here.
Test this now to see how it workd by starting the slide show. (On the Slide Show menu, click View Show.) Advance to the slide with the movie, (best if you have the title of the movie on it). Within a couple of seconds, the movie starts to play full screen. When the movie finishes, you return to the same slide (but no unsightly box appears). Click to advance to your next slide.
Add an On Click effect to start the movie If you prefer, you can click to start the movie. This requires one more step, setting an On Click animation effect.
1. On the Slide Show menu, click Custom Animation. The Custom Animation task pane appears on the right side of the PowerPoint window.
2. Click the movie object (the rectangle) to select it. 3. In the Custom Animation task pane, click Add Effect, point to Entrance and then click Appear. You have added an
On Click effect. The animation effect you added is the one with the
Green star next to it and a gray rectangle around it. If it doesn't have a gray rectangle, click it to select it. Your
Custom Animation task pane should look like the picture below (except with the name of your movie in the list).
4. The last step is to move that animation up to the top of the effects list.
To do this, make sure the animation effect is selected, and then click the Up Re-order arrow at the bottom of the Custom Animation task pane. Or simply click and drag the animation effect to the top of the effects list.
5. Your effects list should now look like this: 6. You are done. Test this to make sure it works by starting the slide show.(On the Slide Show menu, click View Show.) When you advance to the slide with the movie, you should not see the movie. When you click the slide, the movie zooms to full screen and plays. When it finishes playing, you are returned to the same slide. Click to advance to the next slide.
Souce:
How to insert a Movie (or video) into PowerPoint 2003?
I have the same problem. Koss KD 305 dvd player. I was checking the set up menu and I think I pressed OK on the PAL/NTSC button.
Now the picture rolls down horizontally.
I've disconnected it the AC cord many times, but it won't "reset".
Any advice? Thanks
