SOURCE: Toshiba Lamp Reset - How?
Not positive, but I would assume the same as my Toshiba.
With the on, input, and menu buttons held down, insert the power cable.
Hope this helps, NGK
SOURCE: HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
SOURCE: toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
SOURCE: how to reset lamp hours
Supposedly the lamp has a chip that keeps track of the used time. The manual says to check in the instructions that came with the lamp. Others say that LG will not reveal how to do it. Perhaps you could ring LG service and give them your machine serial number and request that as the owner you want the correct information.
SOURCE: How do you reset lamp hours on a Toshiba TDP-Tw420
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
