SOURCE: touch screen not working
I have the same problem with my HTC touch everytime my phone loses service for a few hours the touch screen no longer works but they keep telling me that I have water damage so just because the indicator is pink (its in a stupid place anyways) I have had to pay for three phones and I got one free
SOURCE: laptop won't power on
A few things to try:
First remove the battery from the laptop plug in the power adapter and see if it powers up without the battery in. If this works there is a problem with the battery or the battery driver. If it works login go to device manager and disable the Microsoft ACPI-Compliant Control Method Battery. If battery works then it was the driver if still fails its a dead battery.
Try with just the battery it is probably dead though as its had no power to charge it.
Check if the power adapter has a light on it some have lights that indicate its receiving power. Also check if the lights on the laptop to say the battery is charging even though you indicated it isnt.
Let me know how you go or if you need further help.
SOURCE: QTRONIX joystick for a Quickie P200 wheelchair diagnostics
Any reputable dealer will have a PnG or Qutronix programmer that plugs into the chair in order to program the profiles. This dealer obviously does`nt know that. Call a different dealer.
SOURCE: CTM HS 2800 2 yellow lights flashing after new batteries install
As her to explan to you how she recharges the batteries and how often she recharges the batteris, make sure she is following the owners manual. http://www.ctmhomecare.com/PDF/Owner_Manual/User%20Manual-2800%202800.pdf Explan to her the batteries can NOT Overcharge, Also trace the wiring for breaks or disconnections.
Testimonial: "Thank you, found the problem the tech had the battery cables wrong. I redid them and is working now Thanks!"
SOURCE: flashing battery life lights, quickie 525s
The chair is either in freewheel or the number of flashes will indicate an error code to tell what the problem is. Look in your users manual for error codes or contact Sunrise Medical Tech support
