We've fitted the belt to the pulleys and the drum but the belt is still slack.
Hi.
On some models it is possible to fit the belt on the tensioning pulley or pulleys , the wrong way.
Assuming you have the correct belt, then I suggest you try the belt on the pulley a different way.
Hope this helps.
There should be some kind of tensioner around the motor or one of the pully's. The other problem could be that the belt you bought is the wrong one for your model. If you still have the old belt, measure the new belt against the old one and the new belt should be slightly smaller. I hope this info helps.
