I brought a new usb cable for my samsung sgh b100 mobile phone , when i plug the cable to my system it displays an error message saying that... "usb not recognized 'one of the USB drivers attached to this computer has malfunctioned, and windows does not recognize it,for assistance in solving this problem,click this message .' "
but i have installed all the things which was there in my "Samsung PC Studio 3"............
When I installed the PC suite and windows recognised my SGH-B100 phone the Suite software reports another error at start up "Cannot open port and this program is switched in offline mode. After try to switch in online." Any idea what to do next or how to open the port please?When I installed the PC suite and windows recognised my SGH-B100 phone the Suite software reports another error at start up "Cannot open port and this program is switched in offline mode. After try to switch in online." Any idea what to do next or how to open the port please?
You can't post conmments that contain an email address.
You can try this. install pc studio, and then connect your mobile...it should automatically install the drivers..but if that is what you have done then you can try updating the PC studio software.
Do the following steps to updage software update. 1.Take contacts a backup 2.Remove SD card 3.Mobile should be charged atleast 50% Connect your phone to PC via USB cable. Note: Do NOT turn to mass storage mode. Do NOT do anything Open Samsung PC suite. It automatically recognizes your phone and it gets connected. By default, it will check for a new update If there is any new update, then simply follow the steps. It will give u the instruction step by step.
If
you are trying to use a SIM card in your phone and getting a message like
"Enter Subsidy Code", "Incorrect SIM Card", "SIM not
provisioned" or similar messages, then you need an unlock code for your
mobile phone. You may get your code to your service provider Samsung SGH-D600 Unlock Code. I suggest to visit Samsung Unlock Code site, they will supply an accurate code with easy to follow instructions on how to unlock your phone. Once your phone is unlock, it will work with any network worldwide and don't have to stick with one network. Hope this is helpful. Thanks.
go to this url it will help you- http://www.gsmindia.in/forum/samsung-firmware/18939-security-code-for-samsung-b100-guru-100-a.html Don't forget to rate my solution
Below is a detailed solution to your problem;
STEP 1.
Most mobile phones nowadays come standard with a USB data transfer
cable and bundled software utility. Check the box that your mobile
phone came with for the cable and CD-Rom. If not provided with the
software, it may be available as a free download from the manufacturer’s
website. STEP 2. Once you have located your software CD, check the system
requirements necessary to run the software such as hardware
specifications, operating systems supported etc. Install the software
following on-screen instructions, but do not plug in the USB data cable
or phone in just yet, unless the software requests you to do so during
the installation process. STEP 3. Once the installation is complete, the software would usually
require a reboot of the PC before plugging in the mobile phone for the
first time. Then connect your mobile phone to the data, and the cable to
the USB port of your PC. Several phones may display a message on the
mobile display that the phone is now connected to the PC, but if not
don’t worry just yet! STEP 4. Once connected, start up your mobile phone’s software, and browse
through the interface. Most manufacturers offer some form of phone
browser where you can browse through the content on your phone, copying
files onto, or taking files off the mobile. The software utility may
also offer a separate tool for transferring photos and video shot with
your mobile, if this is the case use the utility! STEP 5 .Use the software’s browser or photo utility to
transfer your photographs to your PC. Some software tools provide image
editing tools as well that will enable cropping, rotation, and
sharpening of images once transferred to you PC. Don’t be afraid of
referring to the software’s help file incase you get stuck. The above guide will be of great help to you,as a note of warning;Remember
never to unplug or disconnect the data cable from the phone during a
data transfer or you could end up damaging your phone or loosing all
your data. Thanks and take care
Your best bet is to soft reset the device, uninstall ALL samsung software off you pc including drivers. then ensure the phone is in ActiveSync mode and then install all software from the disc or samsung.com site and then connect the phone.
sounds like you need to uninstall the software, reinstall it and then connect your phone. If you are usng the front USB panels, try the back ones. Sometime the front connectors are USB1 and are not fast enough.
INSERT THE SOFTWARE DISK IN UR DVD ROME > INSERT CABLE IN USB > INSERT CABLE IN MOBILE > HIGLIGHT 3 OPTITONS > NO NOT THIS TIME > AUTOMETECILY SERCHE > FINISH. WHENEVER THE CABLE NOT WORKING THEN REPLASE THE CABLE.
HOW CAN I GET MY PC TO RECOGNISE THE PHONE?
