Motorola Mobility ROKR E8 Cellular Phone Logo
Anonymous Posted on Dec 22, 2017
Cant copy pics to my moto rokr e8 via data transfer cable
It worked before but now it tells me the file could not be copied
and says it may not exist or is being used by another program
ive copied over .jpg before but cant now and have converted the format also but no dice
i checked the size pixel height and width also
  • schwarzreite Dec 04, 2008
    I cant copy images ti my rokr E8 from windows vista
  • ltbeemer2010 Mar 24, 2009
    ok i have put music and pics on my rokr e8 before but i just got a new computer and i loaded the cds on it and now i cant do it and it is coming up as portable device in stead of rokr e8 like it did before i load the disc
    please help thanks
1helpful
How do i copy files from my handset to pc
Hello ,
Using a USB cable you can easily connect your Motorola ROKER E8 to your PC and do the data transfer to and fro.
For that you need a USB cable and a Motorola driver.
Steps to follow :
1) Download the driver and install it on your PC.
2) Using data cable connect your cellular phone to the PC and start doing the data transfer.
Download Motorola 4.9.0 Driver with MotoHelper
* You can also charge your mobile using this.
tip
Forgot my security code of moto rokr E8
I have forgotten my security code of my motorola rokr E8 and my IMEI No. 359612010168879 and mobile is runing slowly so plz tell me security code.
Want to copy my messages from moto rokr E8 to my pc... Plz tel me how to do it ??
Hi,what to need:
Usb cable and the drivers to install the usb cable.
Or Pc suite.(software112.com/products/motorola-pc-suite.html)Use this link to download the PC suite.
Before you connect the usb cable,install the drivers first before connecting usb cable.
After installing the drivers,connect the cable to phone before connecting to the PC.
You can access the messages from the Pc suite and you can copy out the messages through the Pc suite.
If you are having problems after these process, please fill free to write your comment.
Take care.
The media finder in my moto rokr E8 is messed up. It suddenly has stopped detecting my music and picture files that are already in the phone/card memory. I cannot take new pictures and save them... every...
check weather ur memory card is full if full means delete some data and check or else remove the memory card and check it if no use in above means then try to format both phone and memory card
3answers
Motorola rokr e8 speaker stopped working
Hello Sir, There may be many possibilities, like your software issue or any hardware fault.
First just check your sound settings, if not works, then try to reset the phone, if again nor works then you may take it to the repair Center. They will check for Firmware problem or Hardware thingy.
Regards,
Waqar.
3helpful
well, actually i need to do a master reset and the numbers i have dont work
2answers
How do i transfre pics from my moto rokr to the computer,do i need to download any software?
U'll need first to install the software and drivers that came with the cellphone, after that the same software will guide thru it.
7helpful
2answers
E8 ROKR recognized at my PC as camera and scanner
from your phone go to the main menu(select the following) - settings - connections (usb setting- memory card). thats all you need to know for transfering pics music ect. then plug in your usb and it will read every file you are trying to get ahold of
Moto ROKR E8 not showin in safely remove hardware
It just doesn't show, but there's nothing to worry, u can unplug it like that, it won't hurt the phone or ur PC
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
 Mikey
Mikey
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
