I first thought the right channel had gone completely dead. After checking, I found out that the channel wasn't completely dead, but the volume had dropped considerably. I have tested the right speaker and speaker-cable on the amplifier's left channel, and then it works fine. I have also removed all the inputs to the amplifier and tried with other inputs. The problem is still there. My conclusion hence is that the problem is in the amplifier. Anybody having any suggestions on what's wrong with my amplifier? Thanks.
HI..
Have you tried it with headphones to check the balance?
This unit might have a dual volume control inside which would require service.
Either way there's not much you can do without opening it and having a tech look at it.
I can suggest a tech if I knew your general location
