The caller id of the Seimens Gigaset AL285 from NL, Europe, does not work with the BSNL Landline connection.
SOURCE: caller-id quit working
This is a followup to my earlier suggestion. My caller id is working. So, the culprit had to be related to the 9V battery. Just try my earlier solution from 1/20/07. If it works..fine. If not, bye-bye to the phone.
SOURCE: Caller ID not working
I don't think the problem is the FSK vs. DTMF. The manual even states that the caller ID is generally received after the second ring. This is true in America. I lived in India for four months and I never ran into the problem there so... I just can't say how your provider sends the caller ID. It may be that the line is being interfered with. Do you have a DSL line attached to the same device. If so make sure that there is a filter between you phone and its connection.
I am assuming that you tested your line with the other equipment connected to the same location. You may want to reduce the problem to the simplest configuration by connecting directly to the line only no other equipment. If it works add the other equipment until the caller ID stops again. Then you know what is interfering. If you have a monitor set you could listen to the DTMF being sent make sure it is coming between the first and second ring. It is audible if it is there. If you are answering on the first ring you will not see caller ID you have to wait till after the second ring then you should see it, If BSNL is sending the same as American systems. Good luck Z
SOURCE: Talkswitch caller ID from outside calls not working
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
SOURCE: nortel norstar m7310 phone caller id problems
@relax536
to find out your phone's extension dial
Feature *0 Intercom
